    Originally posted by torbvea View Post
    I use RK Kodi beta 5, which gives me stutter free playback an HDMI Pass through is working fine with DD and DTS. Haven't checked if 3D and HD audio works, since I don't use it.
    Link: http://www.mediafire.com/?txdwim8givg8ndm
    does spdif passthrough work with this Kodi version?
      please add hdmi cec https://source.android.com/devices/tv/HDMI-CEC.html
        Since i see more and rk3288 marshmallow builds coming out over at crewrktablets.arctablet.com i was wondering if there is awasser marshmellow in the making? with Xposed working they are really great and work fine on my Pipo tablet.
          I think that even better will be to work on top of Android N, because it seems that has a way better ram management and the fluence/speed and the stability are better even on the beta version then the previous stable versions of Android so better to wait a little bit more to get something really good.☺
            Why? Still 3 to 4 months till the final n comes out. then at least 6 more months till there is something to build on rockchip. Id rather have marshmallow now.
              Hello guys is this rom going to work on the CX 998 CX 998c it has the ap6330 wifi chip I like to try lollipop on this box.
                Has anyone gotten CIFS to work on any versions of this ROM? I have not been able to.
                Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
                  LINK is down, anybody have alternative links?
                    Which link?
                    There are various ones.
                      This box use same as mk902ii use rom i just post in rkm thread.
                        adaptation for remote Tronsmart Orion R28
                        resource_tronsmart_r28_wasser3.0.3 - оригинал
                        http://4pda.ru/forum/index.php?s=&sh...ost&p=47971385
                        209а https://www.youtube.com/watch?v=siRP...ature=youtu.be
                        The cooling system on Tronsmart Orion R28 Meta Wasser2.0.9a)
                          Thanks for the link to the ROM.
                          It comes with resource files for both the R28 and R89.
                          Installed it to my R28 and although I've only carried out basic testing so far, it does seem to work very well.
                          Youtube 1080p is very smooth.
                            Please, can you tell us how we can flash resource_tronsmart R28_wasser3.0.3 on our device? Thanks. I have an Tronsmart Orion R28 Pro with Wasser 3.0.3 firmware.
                            And i want to know if we lose data.
                              Just flash the resource image alone from the extracted zip file using the Android tool also provided in the zip.
                              You won't lose any data.
                                Thank you sir. But can you tell me wich option i have to choose, please. Click image for larger version
                                I don`t want to kill my device.
                                edit. I use resource option and everything is ok, thanks.
