Originally posted by Mario023 View PostIf someone can give me a link of the last wasser Kodi. Thanks.
wasser Kodi-15.2 , may be it´s this what are you looking for; for the latest v3.0.4a it had been recommended ZDMC or superceleron version posted a couple post before. Anyway, if you don´t use PT official Kodi v16.1 RC2 works fine.
Originally posted by Gormar View PostThis command will not work as expected in at least last Wasser's LP ROM because DTB in resource file contains only one SYS_STATUS value called "NORMAL" (echo "n" > /dev/video_state) and there isn't for example SYS_STATUS_PERFORMANCE. That's why last value from overclockmatic DDR frequency table isn't efectively used as in my assumption. Overclockmatic_RK3288 was built with thought that last value should be associated with "PERFORMANCE" mode. To get higher DDR frequency just change penultimate DDR value (600) to some bigger number but do not forget to set 1200 mV for ARM LOGIC in this DDR operation point because it might be required for this SoC to operate DDR-1600 mode in stable condition. 800 Mhz (1600MHz DDR) for DDR3-1600 memory at 1.5V (seen as 1.2V in PMIC (regulator.1) because it is decived by voltage divider on feedback input) shouldn't be a problem. For RK3288 it might because according to this SoC White Papers it is only validated for DDR3-1333 memory.
Note: 670 (646 in real life) DDR frequency might be default in my internal overclockmatic config. In the wild I might have choose different value.
DDR 3
456 1125
792 1200
800 1200
The voltage values that you have on the config files for v1.0.6 and 1.0.7-LP for DDR for the higher clocks frequencies with voltages > 1200, here on this LP rom produce adverse results on antutu scores, making lower and erratic the scores, these come down to 42K to 49K; but making the voltage = 1200, without exceed that value makes the score comes back to the normal. However the device so far on any situation had not crash it or hang it, the device it´s very stable under this FW.
With DDR @ 792 Mhz (1.2v) & GPU @ 600 Mhz (1.25v) & with the CPU @ 1.92Ghz (1.4v) the antutu (v6.1.2) score hit > 57K.
Originally posted by Gormar View PostI like last Wasser's LP ROM quite a bit but there are some quirks that I might want to change. For example GPU operation table contains only two frequency values and the lowest is quite high. [email protected] for idle GPU frequency IMHO isn't rational especially if you consider that this was maximum frequency in first ROM's and this SoC GPU can work with frequency as low as 180MHz at 0.9V. But maybe I don't know something and it can have impact on stability which is rather exemplary in last Wasser's firmware.
GPU 3
417 1100
600 1250
625 1275
The system continues stable after couples of hours turned on & using it.
Can the GPU go higher, for example makes 625 Mhz the middle point and going the higher point to 700 Mhz @ 1.3v?
Edit: on Mali web page, T760 GPU appears 650 Mhz as the frequency value (in 28nm HPM), not sure it´s referencing as a maximum; may be all the GPU frequencies values managed before into the fimwares had been very conservative. Not sure as well what the differences can be between Mali T-760 as it´s reported now into LP the R-89 GPU versus the Mali T-764 GPU as had been told from the original hardware specs of the Beelink R-89.Last edited by BTR11; 19 April 2016, 23:33.
Originally posted by BTR11 View PostRight, so the only way was pushing the value from .cfg file; now I have:
DDR 3
456 1125
792 1200
800 1200
Originally posted by BTR11 View PostIn LP there are several things that had changed, may be that 3rd lowest frequency value it´s not required as you say; so given this, the only way to get GPU@ 600 Mhz it´s using this value as middle point into the .cfg file, because the system will not check the 3rd higher value; this I get now:
GPU 3
417 1100
600 1250
625 1275
I prepared modified resource file with more operation points for GPU and SYS_STATUS_PERFORMANCE mode for memory. After I test it for some time I will release it here. Stay tuned.
RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Hello,
Can anyone confirm if you play a Higher bit rate, lets say a flac file with 24bit 96Khz...
This also will send true spdif in the same bit-rate.
Someone already tested it and off course it played the audio files like in Kitkat....But i hope it doesn't get down-sampled again to 44Khz like in KitKat..
Only interested what the receiver tells it receives true spdif, no hdmi or dac....
I use spdif to my receiver, and with my laptop it receives 24bit....But anyone here tested is with lollipop and the Ubox to a receiver..
I hope it will, and not only by using a dac with an Otg cable...
Thanks!
Originally posted by minonano View PostMe too no WiFi on my ubox, how come it works on 2.09?Ubox R89 2/16Go(5v4a) + Tv panasonic 32 Full HD + Airmouse c120 + 1To 2.5 Toshiba HD.
I am loving the 3.0.4a on my tronsmart orion r28 but the remote does not work. I used RockChip_Batch_Tool_v1.8 to install it. I found http://4pda.ru/forum/index.php?showt...#entry47971385
it has 2 img files kernel and a resource file.
Can i use that to get my remote working ?
Originally posted by bluesmanuk View PostWhere people are having WiFi issues, is it solely under 2.4Ghz or 5ghz too?
Attached FilesUbox R89 2/16Go(5v4a) + Tv panasonic 32 Full HD + Airmouse c120 + 1To 2.5 Toshiba HD.
Originally posted by mackie View PostIt happens with both, here is a video showing what really happens, I have joined a log, except the Syslog app no other apps were installed.
So you aren't even getting the chance to connect to WiFi.
What is the status of Ethernet when this happens (On or Off)?
What is the status of Ethernet when this happens (On or Off)?Ubox R89 2/16Go(5v4a) + Tv panasonic 32 Full HD + Airmouse c120 + 1To 2.5 Toshiba HD.
There are currently 2322 users online. 3 members and 2319 guests.
