    version 3.0.6
    • fixed tvout issue
    • added soft reboot in poweroff menu
    • cleaned up poweroff menu
    • fixed green colour issue
    • fixed bootloop issue by flashing of new firmware
    • set show input method by default
    • updated translations for german language
    • updated google apps
    Firmware download: wasser-firmware-lollipop-3.0.6
    version 3.0.5
    • add support Xposed
    • add menu option to allow (un)root the device (menu Developer options->Root access)
    • add menu option to hide the hdmi screen, it's required for DRM apps (menu Settings->Display->HDMI checking)
    • fix focus issue in Launcher3 when hide/show status and navigation bar
    • add support fullscreen (hide status bar and navigation bar)
    • fix WIFI connection issue
    • add "clear all recent apps" button
    • move multiwindow option from Settings->Display to Development options
    • Improve UI, Video Streaming and System performance
    • cleanup UI
    • update google apps
    Firmware download: wasser-firmware-lollipop-3.0.5
    version 3.0.4
    • add rotation support
    • add support "Adjust display refresh rate" , enable by default in Setting->Display
    • add "lock screen" support, which is needed for multiuser mode
    • add daydream support
    • fix color issue in es file manager
    • fix menu issue in google play video, menu shows now correclty in google play video
    • fix tvout issue
    • fix UI issue in recovery
    • improve wifi and UI
    • cleanup UI
    • add A2 Lite airmouse support
    • add latest security fixes
    Firmware download: wasser-firmware-lollipop-3.0.4
    version 3.0.3
    • add multi window support
    • fix flickering issue
    • add support for wifi 5 Ghz
    • fix some other regressions
    Firmware download: wasser-firmware-lollipop-3.0.3
    version 3.0.2
    • improve 4k video streaming
    • add tvout support (regression in last release)
    • fix power off issue (regression in last release)
    • clean up UI
    Firmware download: wasser-firmware-lollipop-3.0.2
    version 3.0.1
    • fix 4k video streaming
    • fix security issues in stagefright
    • add full support for rk kodi, please use wasser Kodi-15.2 for working DTS/PASSTHROUHT and smouth 4k/fullhd video streaming
    • fix otg issue
    • add support youtube 1080p60hz
    • fix spdif/DTS issue (i don't have equipment to test this, please only test with stockplayer and report)
    • fix many other issues
    Firmware download: wasser-firmware-lollipop-3.0.1
    version 3.0.0 rc4
    • fix usb sound issue, microphone issue
    • add support 10bit deep color
    • add sleep, reboot into recovery, reboot into bootloader in menu
    • improve UI and video streaming
    • fix poweoff button issue
    • fix spdif issue (i don't have equipment to test this, please only test with stockplayer and report)
    • fix some isssue in launcher3 and improve system performance
    Firmware download: wasser-firmware-lollipop-3.0.0-rc4
    version 3.0.0 rc3
    • fix UHD issue
    • fix netflix issue (it hangs during playing video)
    • add AC3 and DTS support
    Firmware download: wasser-firmware-lollipop-3.0.0-rc3
    version 3.0.0 rc2
    • fix crash when using webcam
    • skype working
    • build firmware with release-keys instead of test-keys to improve app compatibility
    • fix partition issue which causes boot loop (regression rc1 release)
    • fix microphone issue (regression rc1 release)
    Firmware download: wasser-firmware-lollipop-3.0.0-rc2
    version 3.0.0 rc1
    • fix UHD/HD resolution issue
    • firmware now based on release-keys instead of test-keys to improve app compatibility
    • fix spdif issue(i dont have hardware to test this feature)
    • add nextflix support
    • add google play movie support
    Firmware download: wasser-firmware-lollipop-3.0.0-rc1
    version 3.0.0 beta6
    • fix rotation issue
    • add spdif support (i dont have hardware to test this feature)
    • fix crash in skype, skype should work fine now
    • fix crash in data usage=> ethernet
    • add power off button in navbar
    • add longpress menu key to show/hide navbar
    • fix display scale setting issue after reboot
    • fix flickeriing screen issue
    • AC3 and DTS support in rkvideoplayer
    Firmware download: wasser-firmware-lollipop-3.0.0-beta6
    version 3.0.0 beta5
    • add exfat support
    • multi partitions support
    • add new mouse pointer
    • fix issue in recovery
    • add ethernet menu in setting
    • UI improvement
    • fix random ethernet MAC adress
    • fix green color issue on some TVs
    • update busybox
    Firmware download: wasser-firmware-lollipop-3.0.0-beta5
    version 3.0.0 beta4
    • ir remote full support
    • fix some minor issues
    Firmware download: wasser-firmware-lollipop-3.0.0-beta4
    version 3.0.0 beta3
    • unified storage (emulated SD)
    • fix the issue with "black screen when mouse is on the lower screen edge"
    • fix permision issue on storage
    • add hardware keyboard menu
    • disable force encryption of userdata partition
    Firmware download: wasser-firmware-lollipop-3.0.0-beta3
    version 3.0.0 beta2
    • youtube 1080p support
    • init.d support
    • nfs filesystem support
    • rooted
    • add statusbar
    • multiuser support
    Firmware download: wasser-firmware-lollipop-3.0.0-beta2
    version 3.0.0 beta1
    • firmware based on lollipop 5.1.1 release
    • support HDMI sound
    • support tvout
    • support AC3 and DTS sound
    • support ethernet
    • support wifi
    • support bluetooth
    • support LED
    • add support "dont wake up devive with mouse movement in suspend mode"
    It's the my first firmware release based on lollipop 5.1.1, all basic stuffs should work fine. be warned, it still has some bugs,
    and many features are still missing in this release. Please report feedbacks so i can improve it in future release. Thanks
    Firmware download: wasser-firmware-lollipop-3.0.0-beta1
    Howto get log files: get-a-logfile
    hi wasser,
    ugoos ut3 does it support ?
      THX Wasser.
      I've got a question.
      Does this firmware have unified storage (emulated SD) and youtube 1080p?
      If yes then I will try it tomorrow .
      RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
        Originally posted by Gormar View Post
        THX Wasser.
        Not yet, im still working on these features.
        Wasser
          Is Optical spdif audio being worked on Wasser, no option for it in sound manager ? Seems quite solid apart from that, for me. Got smooth video in vanilla kodi isengard beta 2
          Also screen scale is reset on reboot of the box.
            1.I have the problem with bluetooth mouse. Mobile phone was connected without problem, but the mouse - not. I tried 100500 time. On previous, wasser v2.0.9 - mouse had connect always normal
            2. "Power off" -not work. Rebooting.
            3. Remote not work
            My box is ubox
              I installed your new Lollipop firmware half an hour ago on my Beelink R89 (8gig version) and testing it now. I am using Ethernet and have not tested WiFi or Bluetooth yet. First observation, it is not rooted, so the rebooter app will not work. I installed the newest nightly Kodi 15 and it does have Dolby passthrough, thanks, it does however still have that audio hiccup every 3 seconds. It does not have the bottom task bar that I can find, I do like that bar. Also, my stock remote does not work, it did not work on your other firmwares either, but not really a big deal for me. Also, I noticed that it only has 1 gig of memory.
                Netflix will not load, screen with movie icons shows up, but when I click to show the movie, I get the little circle that says "loading". I successfully connected my bluetooth game pad, G910. WiFi will not turn on.
                  Wasser you are the MAN! First lollipop rom on the 3288 tv box Hopefully other boxes Manufactures will follow suit i have to see how to change to use on the mk902ii i quess changing firmware and swapping parts out like in kitkat a whole new learning curve for lollipop
                    Originally posted by wasser View Post
                    version 3.0.0 beta1
                    Great Wasser, impressive!, You are the best!.
                    ------------------- Side Note:
                    Wasser provides firmware for Beelink RK3288 with support from Beelink and based on their latest code from Rockchip.
                    So it won't be beneficial for them to also release stock firmware with less features.
                    Wasser, If moe123 it´s right on that statement, that means that your roms for Beelink R-89 - RK3288 are now the official firmwares for this device? If this is a fact, I have to congratulate Beelink for that clever and bright decision; the v2.0.9a would be the last fimware on android 4.4.2? and from now on the firmware development for the R-89 will be based on android 5.1.1?.
                    Thanks for your excellence in benefit of freaktab users.
                      Great idea to port Lollypop to the R89! Wasser you are our hero!
                      I've installed tje new rom. As user clarkss12 said the rom is not rooted. I was not able to root it manually (tried towelroot and rootgenius). So no way to reinstall apps with TI-Backup.
                      There is no statusbar and no notificationbar. If I move mouse courser to lover or right screen edge the screen gets dark.
                      Stock remote does not work. Wireless USB keyboard/mouse working fine.
                      This version is too "beta" for me. So I went back to 2.0.9a for now.
                      I think you will be the one that will give us a perfect working Lollypop!
                      BTW why don't you a donation button?
                        Anyone tried bobs easy root on it yet? ?
                          Hello Wasser.
                          Nice work once more !!!!
                          I tried it on my Tronsmart R28 pro.
                          What works:
                          Ethernet and bluetooth.
                          What does not work:
                          WIfi and remote control.
                          Plex (the main reason I use the tv box) has some little hiccups but It works well enough. DTS and AC3 work fine.
                          I get an issue with the screen getting black but mouse pointer still visible if I the mouse is on the right side of the screen or on the bottom of the screen.
                          Also the screen gets black if the mouse gets on a pop up box like the one with "power off" and "restart" when you press the power button. In that situation, all the screen goes black except the pop up box and the mouse pointer.
                          I can't get the bottom and top bar to show like in 2.09 and previous versions by clicking with the mouse and dragging upwards or downwards respectively.
                          Some one in a previous post said it shows him 1GB ram. Mine shows 2GB ram.
                          Hope it helps.
                            Originally posted by chrisarchon View Post
                            Hello Wasser.
                            What works:
                            What does not work:
                            Hope it helps.
                            WiFi won't logically work because of the chipset in the pro being different and the remote will likely never work until we have Lollipop kernel/resource images etc from Tronsmart to replace the ones in the ROM to give functionality
                            I was surprised that it ran at all, as I tried it on my Meta,not expecting it to work anyway and found that after flashing, it stopped at recovery with an error message about the cache.
                              What would I need to try this on the UT3? Any plans for an SD boot version?
                              Thanks.
