Originally posted by PsyDonia View Postok
when i connect the box to my computer have the box off use a tooth pick in av hole and press power ill get into recover mode . but my computer dont find any device.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by PsyDonia View Postthanks all. will test that out.
i have computer nearby the media player. but another question.
isnt there any flash tool for android. so you can use an android tablet to flash you android media player/tv box.
Hello,
thanks a lot to Wasser for this great firmware. I have installed it on Cloudnet CR11s tvbox and met the following issue :
1) Ethernet is not working (not the same driver i guess)
2) Bluetooth also not working
I've been looking for days a way of embedding the stock rom drivers but it looks quiet difficult since i should probably recompile the kernel...and unfortunately i don't have Wasser sources.
Actually, i was even blocked at unpacking the kernel.img file since i guess the drivers are located in it.
Once i will have a Linux env, i will attmept with 900supersport android rom kitchen but i don't have it yet for now...
Any help will be apreciated !
There are currently 3371 users online. 0 members and 3371 guests.
