I installed beta4 on Ubox R89 and:
wifi doesn't connet at all it keeps turning on and off , it works with no problem in safemode
FC when you go to data usage=> ethernet
Name of apps with letters like P Y J... appears cut in half in home screen
Can you add a power button to the nav bar
Can you add the wifiDisplay app like in the original firmware.
I'll test Beta 5 and report tomorrowLast edited by mackie; 24 June 2015, 19:54.Ubox R89 2/16Go(5v4a) + Tv panasonic 32 Full HD + Airmouse c120 + 1To 2.5 Toshiba HD.
Originally posted by digitalriver View PostAP6210 not supported? on beta5 wi-fi dont work too
It's unlikely to as the AP6210 is on the R28 Pro and Wasser had said on a thread for his KK ROM that he won't officially support the Tronsmart Orion.
When Tronsmart release their LP ROM then you will likely be able to use the resource and kernel images from that in conjunction with Wassers ROM to make it work.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by mghb View PostHi Gmac,using a beelink 16gb just reflashed to beta2,booted in about 4 min,boot just loops in beta 3 4 5
ut it is true that it sometime loop endlessly at boot "Wasser" logo. Then you should try to disconect any USB devices and even remove SD card.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Mario023 View PostHow to turn off or do reboot on the device?
I have pc mouse
Originally posted by theeze View PostDoes the LP version still have that random muting or is it gone?RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
There are currently 5198 users online. 3 members and 5195 guests.
