Wasser.... Thanks for the never ending efforts.
My experience with your RC1 version (using default player and mxplayer) :
No video stutter at all (with such an amazing smooth video quality) , but sadly , truly sadly (no spdif passthrough) using optical cable.... Which used to be working fine on your 2.0.7 onwards k.k. Versions
(i'm using a harman/kardon av receiver with my beelink R89)
rc1: in a original beelink 16gb
youtube 1080p-ok
video:
1080p resolution-ok
4k resolution- ok on first boot, if you change 1080p to 4k, the screen freeze..
if you change 4k to 1080p or minus, run ok
4k-60p dont have... none firmware have this..why.?? my tv is a sony 4k..
some screen flicker some times (but no in aplication/ movies)
some launcher app and some web-browser have bugs.. but a lot of programs, emulators, games run ok.
(any launcher can freeze screen.. oh..god)
antutu bechmark ony run in 4k resolution, in 1080p freeze..
5ghz, run ok
bluetooth run ok..
kodi not detect 4k resolution.
no youtube 4k (vp9)
BACK TO wasser-2.0.9a-beelink-r89-rk3288
I was having a lot of freezes and crashes on this RC1 and a lot of new bugs including:
. maximum resolution working was 1920x1080p-60.
. No image on boot/restart (always need to connect the HDMI cable to a small screen with 1920x1080p-60 first then disconnect the cable from my small screen and connect it to my TV)
. No passtrough
. Some TV Series stop playing well in KODI
I just come back to 2.0.9a and everything is working properly.
I'm done with RC1. Going to wait for future releases to test it.
I solve the problem that I had, for every one wich upgrade to windows 10 notice this, the RK drivers will be erase so if you whant upgrade like before you can`t because the PC will not recognize your device anymore even that in the windows 10 upgrade option sais that will keep all your files so download again the RK drivers in order to upgrade like before. I see some flikering from time to time but never on the aplication or video but on the menu also I use an 2560/1080 ultra wide 21/9 monitor and I try the 4K option, I must reboot the device because the screen become black, it would be nice to see those resolution options till 4K and I`m refering to 2560/1080p and 2560/1440 2K, those options would be very good indeed many of us have those monitors but very few have 4K TV or 4K monitors, in all the other matters the sistem run very good very fast and stable also, by the way my device is the Tronsmart Orion R28 Pro. Good work like allways!
arggg did I do something wrong? After flashing rc1 once Android tool downloaded and verified and rebooted the device and started formatting /data../cache and started up for the first time, I disconnected and shut down my pc. I think it was down all the flashing at that point but I am stuck on the Wasser splash screen. Doesn't look like its gonna get past that.
Wasser you're ROM is just great. I have an RKM V5 stick who suffer from the HDMI audio bug. I've flashed your fimware (RC1), it works great! No more audio bug. I've lost the wifi (i guess R89 use the AP6335 where mine use the AP6330) but everything else works as it should (Bluetooth, ethernet...).
If i may ask something, it would be great to have a version with the AP6330 driver. It's now a daily driver for me.
There are currently 5041 users online. 0 members and 5041 guests.
