Originally posted by mackie View PostFor me with this rom every single video I play is in kodi wasser the audio is out of sync, the ubox is connected directly via hdmi to the tv .
http://www.mediafire.com/download/tx...v7a-Build2.apk
Originally posted by TheCritter View PostTHX for the great 3.0.3 firmware
Whit the Kodi that I extract from Ugoos UT3 Rom (v3.0.2b) the Firmware is almost perfect.
- Passthrough with DTS-HD and TrueHD works without dropouts, with 23,976fps too
- 3D iso files with 23,976fps works too with HD sound
- the one thing is I must on every movie set a delay from 250ms
- ok a second thing is the icons if I play a 3D movie are damage
Originally posted by gridlock View Post
hi , kindly , can you provide a link to the extracted kodi? thanks
Here you go.
Originally posted by bryanhk View PostUbox R89 2/16Go(5v4a) + Tv panasonic 32 Full HD + Airmouse c120 + 1To 2.5 Toshiba HD.
Originally posted by bloodgnome View Post
3.0.2 and 3.0.3. 5ghz works with 3.0.3
Router AVM Fritzbox 7490.
I found another bug... seems the TV Out is gone again with 3.0.3. Worked fine with 3.0.2
Thanks.. I tried connecting to 2.4Ghz/5Ghz on two routers Asus AC87U and Dlink 860L. Both having same connection issue. Few other devices connected without issue. Any other users with similar routers and connects ok on wifi?
Hi
I had the same Problems with Wifi on my UT3 with every LP Rom until now.Ugoos/Mo's & Wassers LP Roms.Only Mo's 1.3 i dont know did not test until now.I use a XS BoxGO F97,its a 3g Wifi Router.
Wassers Roms are very nice,best is unified Storage,but on my UT3 always the USB OTG Port doesn't work if i flash one of Wassers Roms.Looks like Wasser is a German Dev??????
Es grüßt,Greetings
gefatternLast edited by gefattern; 25 January 2016, 07:45.
Originally posted by kolyan222 View PostHelp. http://www.freak-tab.de/wasser/wasse...-rk3288_box.7z download error.Please consider making a Donation to freakTab
On facebook ap the option to stream HD dose not exist, on 3.0.2 that option work great so you only can see at a poor vdeo cuality. Also a big problem especially for big TV users it`s the lack of the huge option on the font size menu, all the caracters on the google browser are so tiny that you can`t reed anything f you are 3-4 meters dstance away from TV, On the 3.0.4 the next should be rentegrated that huge option even extra huge option would be a very good thing.
Originally posted by Laurentiu View PostOn facebook ap the option to stream HD dose not exist, on 3.0.2 that option work great so you only can see at a poor vdeo cuality. Also a big problem especially for big TV users it`s the lack of the huge option on the font size menu, all the caracters on the google browser are so tiny that you can`t reed anything f you are 3-4 meters dstance away from TV, On the 3.0.4 the next should be rentegrated that huge option even extra huge option would be a very good thing.
Wasser changed that value from 3.0.2 to 3.0.3 . Don't know why though...
Originally posted by bluesmanuk View PostTronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
There are currently 1837 users online. 1 members and 1836 guests.
