    Originally posted by torbvea View Post
    Thanks for the update Wasser!
    Did as recommended a few posts back, installed version 3.0.3 and than directly upgrade to 3.0.4a. When I installed 3.0.4a directly I got some errors and then just a never ending boot animation. The videoplayback is perfect with Superceleron Kodi. As mentioned earlier, it would be nice if the "close all" button could be implemented again. The only problem I have is that power off from the menu doesn't work. I have to hold the power button on the box to turn it off. I have a Tronsmart R28 Meta, does anyone else with the same device have this issue?
    I have Tronsmart R28 Meta yesterday I tried to install UT3 3.0.4 pached and i had the same problem . That is, after installation, the system hung up on animation at startup. What about hibernation? it is working or not ?? I have Ugoos Stage 3 now.
      I initially had the never ending bootanimation issue too but then installed 3.04a directly on top of a fresh 3.03 and it worked OK.
      My Meta do power down correctly. I have the first revision of the Meta board.
        I think I have a newer revision of the board, but the power menu was working fine with v3.0.3. Will check if hibernation is working properly.
          That sometimes happens to me too. But most of the time it works. If you realy can not power down this box then try to reboot into fastboot or recovery and after that cut the power.
          RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
            I tried again today, and now everything on the power menu seems to work properly again, strange..
              I try again update my tronsmart to UT3 3.0.4 pached , but first where can I found wasser 3.0.3 ??
              How can I check what revision of the Meta board I have ?
                You can find 3.0.3 in the first post on page one. I think the only way to find out which board revision you have is to open the box and look.
                  One more question. What is the differences between Wasser 3.0.4 and UGOOS UT3 patched 3.0.4 ?? Which is better?
                    This will always be an open question because people have differing uses for their machines and what may be best for one won't be for another, so the best thing to do is try both and see what suits you best.
                      The only way I can get 3.0.4 to install is to install 3.0.3 first. It's not that big of a deal for me, just an observation. I have tested this on the Tronsmart meta, pro and beelink. Also the ES File Explorer file name text color doesn't seem to be fixed. I still had to change the text color to white manually. Again, not a big issue, but noting this for others that may have the same issue. I also have the 5.1 audio issue over SPDIF with MX Player that others have mentioned. For MX player this 3.0.4 rom is a step backwards. For me 3.0.4 doesn't change anything with SPMC, Kodi, ZDMC. None of them can play DD 5.1 MKV. I use Make MKV as my ripper.
                      Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
                        Originally posted by Rusk View Post
                        I don't tried ugoos stage 3...
                        In UT3-3.0.4-patched firmware, I don't see stuttering in video 1080p from local resources (LAN, HDD). But in YouTube 1080p - there are still
                        Rusk, thanks for making / compile this rom, I had tested your Ugoos UT3-3.0.4-patched wasser 3.0.3 on Beelink R-89, indeed it´s a good rom, these hybrids using as a base Ugoos stock rom produce a very good results on Bellink R-89, with the same handicap of any Lollipop rom, which it´s the lack of compatibility with xposed framework, even with the experimental release from XDA, which it´s a minus on any LP rom versus KK (in fact KK Ugoos stage 3 rom for R89 it´s may be that can obtain the best performance overall on these devices R89 - R28 amongst the different roms flavors).
                        But there is a situation with WiFi 5Ghz band - AC protocol; whilst in wasser v3.0.3 & 3.0.4a the R89 can see or can detect any channel all the way up from 36 to 165 channel, in your Ugoos UT3.0,4 the R-89 cannot see the channels 132 to 144 which it´s where I had configured my router because thru these channels the Router can output more power through those channels with less interference in my place. Can you check this please?; I don´t know why if the rom it´s patched with wasser 3.0.3 kernel & resource images, why it´s this occuring if in wasser it´s Ok?; or may be it´s some inside system.img from Ugoos.
                          Unfortunately, I do not have the necessary knowledge to check or fix this problem.
                          I can advise only to patch it by new Wasser 3.0.4a. I extracted resource and kernel, try, maybe it will fix the problem...
                          In addition, for users Tronsmart Orion R28 - IR Remote support in Wasser-3.0.4a - resource+kernel_tronsmart_r28_wasser304a.7z
                          Tronsmart Orion R28 Meta (UGOOS UT3 3.0.4 patched)
                            If I flash this rom over Ugoos 3.0.4 patched wasser 3.0.3 on Tronsmart R28, will all my data and apps will be removed?
                              If just flash the resource and kernel image only from the extracted zip file using the AndroidTool, You don't lose any data. Click image for larger version
                                If just flash the resource and kernel image only from the extracted zip file using the AndroidTool, You won't lose any data.
                                [ATTACH=CONFIG]n567474[/ATTACH]
                                I'm currently use Ugoos 3.0.4 patched wasser 3.0.3.
                                If I understood you, I need to flash wasser 3.0.4a (system.img) and from your zip (resources.img, kernel.img)
