    Hello, first of all thank you for your amazing firmware, i have the beelink R89, used orbsmart s92 rom, that seller provided me, and now i have the wasser 3.0.3, the 3.0.4 locks my device in loop with the screen moving Wasser... the 3.0.3 works good...
    i have some problems... with all firmwares i tryed... sometimes my device stops for half second... and i even bought a new ac adapter with 4A, to try to solve it... i dont know if someone have that kind of problem... or its connected to my hdmi switch...
    Anyway, my biggest problem, is that the device plays all the videos h264 h265 very good, but when i use the tvheadend client in kodi, or even VLC to play the m3u stream... i only get sound, and to have video i have to force software decoding... HD channels get very blurry, and cpus working at 80 to 90%...
    the tvheadend server is a wetek play with dual tunner dvb-s2... in windows everything plays nice... but on the android box... no :/ how can i solve this? if i have the file on the hard drive, it plays good, if its streamed its bad :S
    the stream format is h264- MPEG-4 AVC (part10) .
    thank you.
      Is any posibility to flah stock Tronsmart ROM on an R28 Meta, after Wasser 3.0.3 ROM? I flash Wasser 3..0.3 and it crashes frequently. I tried the original firmware but can not get past the boot screen.
        Yes, but in the Russian only forum - 112K for Tronsmart R28
        Tronsmart Orion R28 Meta (UGOOS UT3 3.0.4 patched)
          Hello!
          I have Tronsmart R28 Meta. What is currently the best firmware? Is UGOOS UT3 patched 3.0.4 I can upload to my R28 Meta? How is it best done? I currently have Ugoos stage 3.
          Regards!
            Yes.
            This firmware is the best for me!
            But there is a opinion, that success depends on the revision of the system board...
              Originally posted by Rusk View Post
              Yes.
              have you tried earlier ugoos stage 3? what about sutterin on 1080p ? there are still on UGOOS UT3 patched 3.0.4 ?
                I don't tried ugoos stage 3...
                In UT3-3.0.4-patched firmware, I don't see stuttering in video 1080p from local resources (LAN, HDD). But in YouTube 1080p - there are still
                  Thank you, i will try.
                    what about led in hibernation ? glowed red?or still blue ?
                    and you have tronsmart R28 Meta or Pro ??
                      LED in hibernation glowed RED.
                      I have Meta (see my signature)
                        I am trying to upload a firmware and I have a problem. After loading everything and restart the system hangs at the logo "UGOOS STAGE"
                        How to fix it ??
                        I re-flashing to UGOOS Stage 3 and is fine now. Whay I cant update to UT3-3.0.4-patched? Anybody help me? I try 3 times and still the same hangs on boot screen UGOOS ....
                          Recommend, first flashed Wasser 3.0.3, and then immediately UT3-3.0.4-patched
                          i don't know why...
                          But maybe this is not successful, because of the revision of your system board
                            Hi
                            who made the ( UT3 patched ) Firmware???,and what is the difference to 3.0.4.
                            I have a UT3 and want to give it a try.
                              If You have real UT3, I think this is not good idea... This firmware for Tronsmart R28 (by default) and Beelink R89 devices, because it contains resource.img (patched for Tronsmart remote control) and kernel.img from Wasser.
                                Thanks for the update Wasser!
                                Did as recommended a few posts back, installed version 3.0.3 and than directly upgrade to 3.0.4a. When I installed 3.0.4a directly I got some errors and then just a never ending boot animation. The videoplayback is perfect with Superceleron Kodi. As mentioned earlier, it would be nice if the "close all" button could be implemented again. The only problem I have is that power off from the menu doesn't work. I have to hold the power button on the box to turn it off. I have a Tronsmart R28 Meta, does anyone else with the same device have this issue?
