Hi Wasser,
On the previous Android 4 for R89 you had a update-cpu file
OC kernel: update-cpu1920-ddr700-gpu625.zip
There is no need to install this file with version 3.0.2?
First of all: THANKS FOR ALL OF YOUR WORK ON THE RK3288 CHIP!! ROCKCHIP SHOULD PAY YOU MONEY FOR DOING THEIR JOB..
Feeback:
Hardware: RK3288
Vendor: Rikomagic
Model: 902ii.
Just install your Beelink 3.0.3 on my box because i was having some problems with audio passthrough..
This version came without Kodi installed and official versions dont have DTS-HD MA support.. then i tried this version from Mo123s thread: (hope it is okay to link to his work?)
http://www.mediafire.com/download/tx...v7a-Build2.apk
It has support for DTS-HD and it is working flawless on your version.. For the first time iam able to run movies (40gb Remux) With DTS-HD MA enabled without any audio hickups or any other problems..
DTS and DD is working too without any static..
But iam not able to connect to my server using NFS or SMB? Is this deactivated in your kernel? First time i am having this problem on the roms i have tried..
I need to use FTP in Kodi to connect to my server..
3.0.3feedback
HDMI Passthrough turned on
MX Player with custom codec
Flawless playback of pretty much everything, with sound coming through perfectly.
5.1 and DTS is perfect with a slight delay before playback.
All of my 10 bit files played flawlessly.
Jellyfish 100/120Mbps files showed heavy stuttering as with the previous ROM but not really concerned considering the high bitrate of the files.
As before the only HEVC file that had heavy stuttering was a .TS file but that has never played well on RK3288 (did play well on the RK3368 ROM)
Colour reproduction and depth stunning as usual.
Youtube
Superb 1080p playback with an occasional micro stutter every 30 seconds but so minor as to be hardly noticeable.
BBC iPlayer (Beta)
Perfect playback.
Internal video player
For all the videos that it supports (which is less than MX Player), the same quality results as MX Player.
Kodi 16 Beta as mentioned above by Thomasqqq
Playback generally good but micro stuttering with 4k and high bitrate files.
Dolby 5.1 audio was flawless across the board but DTS was hit and miss. Sometimes it would just not produce any audio and I had to exit and restart Kodi to get it to play again. Once 1 file does not play audio, none of them will.
All 10 bit files played well, which I wasnt expecting at all.
BBB 1080p surround - perfect.
Files with Dolby Truesound did play audio but only as regular stereo (better result than MX Player and not expected to play in full audio glory on my sound bar)
The .TS files that would not play well in MX Player played flawlessly.
Planet earth pole to pole MKV file stopped playing video part way through but continued to play audio.
All general video files played back very well.
General ROM usage
As usual, all is very fluid and fast in operation.
WiFi and Ethernet speeds very good across the board.
Colour reproduction, depth and clarity absolutely superb across the board with all players.
For me, my R28 Meta is still the best Android box that I have.
RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View PostCan anyone confirm if there is no problem with task bar in this new ROM with multi window mode enabled?
I mean that application icon fills only half of available space on bottom task bar and clock is always set to China's time zone (UTC+8).
Like on this screenshot:
[ATTACH=CONFIG]n548955[/ATTACH]
I don't get any of the icons only filling up half the space as shown on your screen shot but there seems to be unused space along the bar for more apps to go into.
My clock stays correct when in this mode.
Originally posted by bluesmanuk View PostI don't get any of the icons only filling up half the space as shown on your screen shot but there seems to be unused space along the bar for more apps to go into.
For me in mo123 Light Biz OS v1.2 for some reason there is invisible boundary exactly in the middle of the screen. It looks like task bar is working in split screen mode.
Thanks for info about the clock in task bar. It is most annoing to have it shifted for so many hours. This is the reason to change to Wasser LP LighBiz edition. One more question in that matter. Can it work in 24-hour format?
Could someone upload screenshot from this new firmware version in multiwindow mode (Light Biz)? Print Screen key on physical keyboard should do the trick.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View PostSorry but I did not fully understood you. Does the application icon fill all of available space (till notification icon) in task bar? Run more apps to check that.
On your screenshot, some of the icons on the bar are not complete, which is what doesn't occur for me.
The number of icons is limited though and there is space to the right that is unoccupied but would seem to have available space to show more of them.
Originally posted by bluesmanuk View PostOn your screenshot, some of the icons on the bar are not complete, which is what doesn't occur for me.
I do not realy know if this is a bug or a feature.
There are currently 2238 users online. 1 members and 2237 guests.
