Originally posted by amclean123 View PostI'll see if I can confirm that.
When such a feature (auto motion plus is set to clear , then there will be no stutter on all roms)....
i just love that extra smooth motion that i can only get with 3.0.0 RC4..... but that's me
cheers
Originally posted by slyger View Post
really? both stock remotes work with no issue on my Beelink R89 and UboxTronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
on thing i've noticed with this image is if you leave the unit on for multiple days network playback seems to suffer. i believe i left my ubox on for 4 or 5 days and network content suffered from massive stuttering during playback. thankfully a reboot fixed the issues. i just wanted to share in case anyone else runs into this. funny enough, streaming content was not affected at all.
Well I hope the remaining bugs can be fixed. Otherwise its a nice and fast firmware.
What annoys me is the fact that the connect to pc option under usb is off after each reboot. So i can't let my airmouse attached to the otg port. Which sucks cause its the only real working port for it.
Also i was unable to get xposed to work. Every version (up to 78) resulted in a bootloop. Maybe Wasser could change something in his firmware to make xposed work.
I've seen tablets with rk3288 running xposed. So there should be a way.
i just used the upgrade tab in Android Tool 2.3 for both of my boxes. Def try it out and let us know! It will be awesome if it works for you as well. If it does, perhaps Wasser or someone else familiar with the details will be able to explain why it works
If you're using the upgrade tab for the 3.0.2 install, what's a clean install? (I've always just used the upgrade tab...).
Thanks in advance.Last edited by Tarwin; 27 November 2015, 04:37.
Something new about Xposed:
Since i got lots of RK3288 devices and all have problems with xposed i tested this one on my Pipo P4 Tablet:
Its from Oma7144 and its Cyanogenmod 12.1 (LP 5.1.1) using the provided kernel i was able to get Xposed running without problem.
I will try to use wassers Kernel with this Hardware as it seems the Xposed incompatibility is due to some stuff Rockchip did with their framework.
If I get it to work it will be the best firmware for now IMO (Fast Lolipop with Wasser Kernel...xposed working ect.).
I have one big problem with 3.0.2 version - no sound. I think it is my Mele F10-Pro that causing this problem. If I remove Usb for Mele air mouse everiting works perfect. I need to install Soundabout app, for sound to work properly with F10-Pro. Is there any solution for this kind of problem?
I have same problem with latest Ugoos UT3 v 3.0.2b ROM.
hello H-Tab, with Mele F10-Pro you have sound.... in the remote!
read this:
The Mele F10 pro controller comes with built in sound but it's designed specifically for the Mele TV box and doesn't work on other makes. When connected to other boxes, it causes android to switch to the Mele F10 sound card which disrupts video playback (stuttering) and there's no sound.
There are two ways to resolve this:
1. (Less technical) Install Soundabout and make sure that HDMI is selected as the sound output (or whatever output you are using - in other words, not USB which is the Mele device). Some people have reported an issue where the HDMI option disappears from soundabout which requires a reinstall of the app to bring it back.
2. (a little more tech but permanent - my personal fav.) Install ES File explorer and edit the audio policy file to disable USB as an audio option- Recommend you do this with a proper keyboard / mouse attached.
- Install and run ES File Explorer
- Under tools (left), make sure root explorer is 'on'
- Click root explorer and then Mount R/W - make sure /system is set to RW
- Then under local (left), select / then in the main window navigate to /system/etc and click 'audio_policy.conf' to edit it (chose ES Note Editor)
- Click the menu and select 'edit'
- Find the line that starts with USB and comment out all the lines in that section like this:
# usb {
# outputs {
# usb_accessory {
# sampling_rates 44100
# channel_masks AUDIO_CHANNEL_OUT_STEREO
# formats AUDIO_FORMAT_PCM_16_BIT
# devices AUDIO_DEVICE_OUT_USB_ACCESSORY
# usb_device {
# devices AUDIO_DEVICE_OUT_USB_DEVICE
# inputs {
# usb_device {
# sampling_rates 8000|11025|16000|22050|32000|44100|48000
# channel_masks AUDIO_CHANNEL_IN_MONO
# devices AUDIO_DEVICE_IN_USB_DEVICE
# }- Click back then save.
- After that reboot (not sure if it's required, but it won't hurt).
(by Arietans)
There are currently 2860 users online. 0 members and 2860 guests.
