Originally posted by bloodgnome View PostDoes xposed work for you guys? I tried the official and the romhancer version (v74 and v75) and both are not working for me...
I've not seen a posted version of Xposed work yet on LP.
Last edited by bluesmanuk; 29 October 2015, 16:34.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Had another go at it and can confirm that out-of-sync isn't a problem anymore once I adjusted via Kodi.
But I noticed the low voices amclean123 described. In fact it does not seem to be limited to voices - everything sounds muted (tested with DD and DTS 5.1). Without passthrough and with MX Player it sounds "normal".
Hi Wasser,
Thank you for your support on the firmware.
My device:
Beelink R89 2G/16G
PCB ver 3.0
1080P@60Hz
Gigabit Ethernet
FW 3.0.1
I have tested Youtube 1080p60hz. It is fine.
But I notice that the TV box will be freeze with red LED light after power off. (The first option in the power menu)
It cannot be powered on unless keep pressing the TV box power button for a few second to power off and then on again.
Regards,
Sintest
Originally posted by sintest View PostBut I notice that the TV box will be freeze with red LED light after power off. (The first option in the power menu)
This definitely did not happen with 3.0.0. RC3
Originally posted by gridlock View Postusing the version 3.0.1 anyone with a beelink r89 will notice a minor , yet noticeable , video stutter using mxplayer .
this issue never existed in earlier rc versions (i.e 3.0.0 rc4)
(Such issue was tested in two beelink R89 boxes)Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by amclean123 View Post
I have a beelink R89 and I spent a lot of time with MX Player and did not see the stutter. I'll look for it again today. I am using neon.1.7.32.zip codec. The neon.1.7.32.rev1.zip codec had problems for me.
The testing was done using neon 1.7.32rev1 , so can you kindly check out the difference in stutter with the mentioned codec? thanksTronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by gridlock View Postamclean123......... were you able to fix the switch off issue for beelink r89 in 3.0.1 using any power off app (e.g reboot app) ? the tronsmart r28 doesn't have such an issue.....
If you get sick of turning it off and on you can simply plug in a powered USB OTG cable into the beelink or tronsmart. This bypasses the need to press the power on button on the box.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
There are currently 4127 users online. 0 members and 4127 guests.
