I use the Meta too and always Eraseflash before I flash the ROM.
Originally posted by chrisarchon View PostHello wasser.
With RC2 I cannot direct play AC3 and DTS in Plex (a problem that keeps coming every few firmware releases)
RC3 release notes state that it's fixed but it isn't.
With RC1 it was working fine.
Just a reminder, I am using a tronsmart Orion R28 Pro.
It's the first Rom newer than the rc1 that AC3 & DTS direct play works in Plex.
I think it has something to do with the changes you do for the ones that have problems with spidf.
Also the power button works again with this Rom . It didn't work with any of the rc roms. You could use it only for powering on the device , not for getting to standby mode or getting out of standby.
I am using a Tronsmart R28 Pro.
More feedback when I play a little bit more with it.
Thank you wasser
Originally posted by marcelomelo View PostI´ve been flashed my beelink r89 device with last version and now i have a blank screen (HDMI not responding).Does anybody know how to fix it?Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by Gormar View PostYou can use tool like RK31xx_firmware and extract from one image firmware file 6 separate MTD partition images, one parameter and one loader.img file. Then flash those files excluding misc.img with Android Tool. Eventualy you can use Android Tool "Advanced Function" tab to extract/unpack single firmware file into aforementioned MTD partition images. But I didn't try this method yet.
Originally posted by grummel2005 View Post
cannot understand one word - sorry
Install Titanium-Backup Pro from playstore.
Do a backup of all your data and apps (save to ext. SD).
Flash the new wasser-rom the usual way.
Then reinstall TI-Backup and restore all data and apps from backup.
Originally posted by wasser View PostEnjoy and dont forget to post feedbacks
first of all thank you very, very much for your great work. Is there any possibility to do a donation?
Here is my first impression of the 3.01 rom R89:
I often have a fickering screen (mostly in the lower part) for one ore two seconds when scrolling screen on apex-launcher or on starting apps or a videos!
Never had that before in older versions.
Videos running stutter free with video-app over hdmi (sound also working).Last edited by uli-hh; 27 October 2015, 13:52.
wasser , it seems that the beelink R89 can't be totally shut off using any power off app.....kindly also check the video playback micro stutter using mxplayer (very minor but noticeable when compared to 3.0.0 rc4)....
don't know , but i can feel that this specific rom (3.0.1) is more dedicated to tronsmart R28 users......
Hi all,
considering a Netflix subscription, so can anyone tell me:
1. Is it possible to stream HD?
2. Can you use the Android TV Netflix app: http://www.apkmirror.com/apk/netflix...-apk-download/
2. No
There are currently 1904 users online. 1 members and 1903 guests.
