Originally posted by sintest View PostHi Wasser,
Thank you for your support on the firmware.
My device:
Beelink R89 2G/16G
PCB ver 3.0
1080P@60Hz
Gigabit Ethernet
FW 3.0.1
I have tested Youtube 1080p60hz. It is fine.
But I notice that the TV box will be freeze with red LED light after power off. (The first option in the power menu)
It cannot be powered on unless keep pressing the TV box power button for a few second to power off and then on again.
Regards,
Sintest
Originally posted by wasser View PostHi all, lollipop wasser firmware version 3.0.2 s released. For more infos, please take a look at the first post.
Enjoy and don't forget to post feedbacks
Wasser
After doing more testing both rk-kodiapp-15.2-lollipop.apk and wasser-kodi-15.2rc2.apk seem to behave the same on 3.0.2 as they did on 3.01. rk-kodiapp-15.2-lollipop.apk still generates audio artifacts during passthrough with the RK Codec.Last edited by amclean123; 30 October 2015, 21:32.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by dimkin View PostAny chance to get ace-player work?
Edit: I don't see Ace on Google Play any longer. If you can post a link to the APK I can test it.Last edited by amclean123; 30 October 2015, 17:24.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by amclean123 View PostI don't see Ace on Google Play any longer. If you can post a link to the APK I can test it.
Originally posted by andreyh View PostTronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
I found some regression with 3.0.2
When using rk-kodiapp-15.2-lollipop, many videos would play with no video but audio only and some with neither.
With wasser-kodi-15.2rc2 things were better and everything played very well indeed using both SPDIF and HDMI passthrough, although I do tend to notice a little crackle at the start of playback with Dolby files.
I have found that Youtube at 1080p has more micros stutters again.
There are also more general continual micro stutters with MX Player although audio passthrough is perfect.
I noted that when connect to PC is selected in settings, it doesn't retain it after a reboot.
I am also using a new 64Gb NTFS flash drive, which is shown as having 0 bytes storage in storage settings and not picked up at all by ES File explorer but can be seen by Kodi.
The power off issues reported by others is resolved.
The opposite it´s the bug, when after a reboot "connect to PC" is always "on" or selected; so in this release that was corrected which it´s Ok.
Originally posted by BTR11 View Post
This is not a bug, this is the correct way as the usb-otg port must to work, which it´s particularly important on R-89 box to can attach to this port any air mouse/ touch pad-keyboard with usb connectors and get the proper performance from the mouse to avoid "lagged" movements and the repeating characters bug noticed on R-89 always when the air mouse is not attached to the Otg port. The same apply for other usb game controllers.
I turned it on and connected a Logitech K400R and suffered no issues with lag or repeating characters.
So maybe it's something more exclusive to the R89.
There are currently 3135 users online. 1 members and 3134 guests.
