Last edited by amclean123; 02 November 2015, 17:12.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by cgsong View PostI'm using the latest 3.0.2 lollipop firmware and rk-kodiapp-15.2-lollipop.apk and everything is great. But I can't install Apple iTunes Tailers video addon with rk-kodiapp-15.2-lollipop. It said that installation is failed. Is there way to install Apple iTunes Tailers video addon ?
Thanks.
Can anyone say, whether this Kodi version within pvr-addons?
Originally posted by bluesmanuk View PostI did test 10 bit files in my earlier feedback and they don't play in MX Player, Kodi or default player..
But I read on russian forum that this H.265 Main10 video file is playing flawlessly and some comment that it has less that 25fps which can have some impact on HW decode.
Or maybe someone saw a slideshow with MXPlayer in Software mode and thought that this film should look like this because it's a time-lapse video which it isn't?RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
They did play in an earlier version of the ROM though, so it is definitely a possibility.
Thanks Wasser for all updates! I have some problems with 3.0.2.
1. Sound is lagging sometimes
2. Small display artifacts, screen flickers (sometimes, often in different settings views)
I added log-file, both problems happend during when i took log. Was using SpotifyAttached FilesBeelink R89
Pioneer SC-2022
Samsung 55" LED 2012
Previous:
Minix X8-H
Minix X5
Logitech Revue
Originally posted by amclean123 View Post
I'd imagine the Orbsmart has a different ethernet hardware. Check to see if your USB ports work. If they work then you are in luck. You can get a USB 2 to Ethernet connector. Geekbuying has one that's worked well for me when the ethernet port didn't work on some of my android boxes.
By the way i have found that Android Tool V2.33 can put the device in maskrom mode by pushing the erase flash button, without shorting the emmc pins.
After hanging on for nearly a year in the hope that Tronsmart would release a decent ROM for the R28, I took the plunge and installer Wasser 3.0.2 yesterday. It simply transforms the box into something that finally works well. No stuttering, no freezing, great 1080P in YouTube... One tiny thing is that it can take a few seconds for Bluetooth audio (in Kodi 15.2) to start up, but once it does, it's fine. Many many thanks to Wasser for making this, and also to everyone on Freaktab and the Tronsmart forums who've taken the time to post guidance on installing the ROM.
Originally posted by soarec911 View PostHi all,there is any wifidisplay app that work in this rom ,i wanna to display my phone(oneplus one) on my tronsmart r28 meta and i want working app on this rom ,please can anyone help.THANKS.
There are currently 2609 users online. 2 members and 2607 guests.
