Originally posted by ytkrc View Postdear friends ; for lollipop firmware versions what is your suggestion for kodi/spmc ? which kodi/spmc version has the best stable, fast etc. ? thanks.
That may be dependent upon the content and specific use that you have for Kodi.
I would advise trying each version yourself in order to know which one suits you most.
I have been using 16.0 Monthly build lately and have been quite impressed with it.
Hi Wasser!
Any news on this issue http://freaktab.com/forum/tv-player-...894#post524894?
Is there easy solution for that?
Thank you in advance.
Hi Wasser,
I had flashed two Beelink R-89 (2Gb/16 Gb) with RC3, both pcb v3.0, but whilst the first device flashed had been working very good, stable, the second one which it´s a little older than the first, the system became un-stable loosing the Wifi (using AC band) and crashing the system, constinously tryin to turn on and reconnect the wifi without success. So, apparently for me, only the newest pcb v 3.0 revision the RC3 Rom works OK, but not on the older.
Originally posted by spi007 View Post
You can use the following app to turn any android device into a Chromecast Receiver. It works great, albeit being a little pricey:
=> just read that google ask them to take down the app from both the Play Store and Amazon Store... well seems like google really dont want people to use chromecast outside of android tv and the dongle.
Cool, thanks for that
Nothing that works as well as with KK but I do think that things are very close to happening.
Please post the feedbacks if SPDIF works!!!
Wasser
Originally posted by wasser View Post
bluesmanuk, or someone with spdif issue, could you please download resource-spdif-ll-19.09.img and flash it.. Please dont forget to download the audio_policy.conf and overwrite the /system/etc/audio_policy.conf before you flash the resource-spdif-ll-19.09.img
Wasser
Done and tested with every player but no sound at all through SPDIF I'm afraid.
Wasser
Hi Wasser,
I tested this img+conf,but spidf not working,
Ubox-R98 , v3.0
I switched back to 2.09a + SPMC 14.2 for spdif.T-R42 v1.0 ; Ubox R89
the same problem
There are currently 4615 users online. 1 members and 4614 guests.
