ill mention that it took fiddling with buttons and the cables in no set order to miraculously flash after about 10 tries. doors allwinner have support because it's rally their integrity on the line should have gotten mk808b plus
Beelink X2 H3 box
this box is very poorly constructed internally. currently for the 2nd time after powering down it gets stuck on boot image. last time i unplugged it, 30 second pin hole reset and it worked but today no go. it's not stable I'm using the 103 rom. gearbest rushed this to market, lied about the maker, and had done crap for support. thankfully we hello each other but anyone else get this reboot and boot loop issue?
My experience of flashing hundreds of times is that flashing images with others for the same SOC does not really risk hard bricking your device.
They are pretty bullet proof these days.
delighted:
it sure does run on 1080p, you can tell at first glance by tiny icons and very small font in UI.
- first, power icon changes from blue to red :-)
- remote does not work, was kinda to expect, nor does the physical power button
- android version fro my taste looks too phone like, and not like a player
- wifi works, but i must admit, it has issues, not quite stable . i even tested the speed by speedtestnet app, and got very funny results like 5Mbit dl/6Mb up speed
- rendering webpages is really, slow, and i got impression i am on raspberry again :-)
- image comes with numer of preload apps - like facebook, netflix, dolphin... yet Kodi is quite naked and needs installation
- i run AnTuTu benchmark, gave me if i can recall 12000 pts, on beelink due to wonderful optimization fast as double - like 21000
- AnTuTu Video Test ran well, mere 2 containers were not playable, one 2K and one real networks one, so no real issue
- you must re-plug the device in order to make it start, and today just trying genesis, i got a number of i/o errors by starting random streams so i got back to original ROM.
but the major thing is - this device *CAN* certainly play with 1080p output, and the results on a monitor were unbelievable. i played my test files h265 and i was
just blown away! amazing quality - pure joy, on my FHD monitor i got "4K feeling" of unbelievable depth.
so, the hardware is amazing, beelink or whoever made the tradeoff with the ROM did actually good thing, made stable ROM, very fast - to hit the market running,
since 64bit/octa core boxes are comming, and they did well with relatively small 1GB RAM - yet at low(er) quality cost, which is a trade off i personally do not like.
i hope, an original XII rom with 1080p player output will come (with support of remote, stable wifi etc.) - ideally it would have UI in 720p, since on tv sets having
FHD output and text to read is a exhausting for the eyes - yet, playing movies should be at least 1080p...
i will keep the gadget, it is really neat, and will continue experimenting with other ROMs.
yet, i think it would be wiser to set on 64bit/octa core gadgets with 2GB RAM to take no compromises...
once again, thanks go out to bluesmanuk - this forum helped me alot!
Originally posted by Aldxproject View Postthis box is very poorly constructed internally. currently for the 2nd time after powering down it gets stuck on boot image. last time i unplugged it, 30 second pin hole reset and it worked but today no go. it's not stable I'm using the 103 rom. gearbest rushed this to market, lied about the maker, and had done crap for support. thankfully we hello each other but anyone else get this reboot and boot loop issue?
i was frustrated as well. but, if you have a microSD card, just use phoenix solution and upload image in that way - follow the solution described in previous posts.
Originally posted by Shanny View PostI flashed the unit using Tronsmart Draco H3 image and did have the red power button which leads me to beleive the unit was flashed but the down side is I'm still getting the "Resolution not supported" message. Will try on another TV to see if that's the issue.
I can confirm, that the output is set to 720p when you flash new rom, regardless to what was it set to in previous rom. maybe it is the problem of your tv set. worst case - grab the box, go to next hi-fi market
and test it on 4k set (unless you owe one already) :-)
neek To get the normal font on 1080p firmware you need to change sys.disp_density=160 to sys.disp_density=240 in system/buid.prop Save the file and reboot.
I hope TRIGTOP can give us a firmware with 1080p kernel. The 720p firmware from them is quite good. I tried to insert Tronsmarts 1080p kernel in to the firmware from TRIGTOP but it does not do anything. It still stays 720p so there must be something else that need changing.
Originally posted by neek View Postit sure does run on 1080p, you can tell at first glance by tiny icons and very small font in UI.
Currently Inactive on Freaktab.com
I use: MK903V | MELE F10 Deluxe | Roku 3600R
RIP: MK808b | MK809III | PIPO M9 Pro
I wrote quite an extensive posting yesterday, but it got lost somehow, let me just tell you the following - yes, flashing Draco H3 image worked, and i was
delighted:
It's good that you had fun trying and tinkering, which can be quite fun at times.
I did also find with my Zidoo X1 that the quality of picture on screen was amazing and as you said, the depth really does make such a difference to the viewing experience.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Hi guys, I got mine today, it's a nice little box, works ok with kodi. However, big problem is that even though I set 1080p resolution in Android, Kodi is showing 720p resolution, meaning it's not a true 1080p kernal, that sucks big time because this thing was advertised to do 4k output, what a shame. Why don't they make proper 1080p firmware for this box. I'm sure it could handle it.
There are currently 2735 users online. 1 members and 2734 guests.
