Beelink X2 H3 box
Originally posted by Haven View Postthanks TRIGTOP for the new firmware everything fine here and better picture quality for MHDtv app
Do you means 1080P UI has better picture quality for MHDtv ? I had tested it and the quality increase so little that I am not sure whether it is proper to release to you. Actually, Allwinner think this quality is H3's practical capacity.
Hmmm... Tried with WinRAR and also get the error message. I will try to download one more time and see if it helps.
C:\Users\Dimon\Downloads\update_XII_v104k4_1080.ra r: Checksum error in update_XII_v104k4_1080.img. The file is corrupt
C:\Users\Dimon\Downloads\update_XII_v104k4_1080.ra r: Unexpected end of archive
Originally posted by TRIGTOP View PostX2 new image for no brand system
Version: android4.4.2_104k4_1080p
Based on : 104k4
Built time: 20150724 14:56
Features: 1, UI resolution changed to 1080p ; 2 ,Android 4.4 UI as default UI and remove 720p MBOX UI; 3, Allwinner LOGO and root.
720p UI for the icons and fronts bigger than 1080p haha.
and here are the results:
(yes, i changed the post, since i easily got backup to work with kodi settings, and restored them with no problems)
update with phoenix went smooth. updating kodi settings also, i tried antutu video test and every file played, top #5 rating!
for those who say there is no visible difference in quality; i thaught that at first glance, but soon relized my mistake:
DON'T FORGET to SET 1080p60 in android options output to start with - because that was pre-set to 720p for obvious reasons.
now, everything is crisp and smooth as ever wanted!
thanks again TRIGTOP excellent work!!!!
complimentsLast edited by neek; 27 July 2015, 18:05.
Originally posted by neek View Post
WOW, you are fast!! I am DL it right now and can't wait to install everything.
compliments
So I tried it, it looks very nice and crisp, however I doesn't support wifi hw on draco card. Therefore I'm going back to Draco's 1080p image.Last edited by amd7674; 28 July 2015, 02:05.
There are currently 5466 users online. 2 members and 5464 guests.
