Beelink X2 H3 box
Box I received has root,
Not a lot of Junk on it (apps I don't need) Kodi 14.2 installed with some extras.
Working OK, found that after 20-30 minutes bit of a pause and loading
so may have been getting a little buffering, worked fine except for the pauses, 5 dropped frame.
More testing
From the few tests I have done this day and for what it is and the price you would have to be happy with one these.
Netflix OK (No HD) WIFI speed fine
I did the Build prop tweak to change res to 1080 looks much better
Now looking to update: Version: android4.4.2_104k4_1080p
Update found and PhoenixSuit followed instructions and all is fine. Loaded OK, Thanks TRIGTOP
Now its 1080 looks much better
Still snappy as before .
More reloading and testing
Cheers
Just another funny Q comming from complete idiots using the gadget i gave the box to;
how to setup the system in order to shutdown it after the single "off" button click on the
remote, or - more important, after pressing the physical one - on the box itself?
people familiar with tv/dvd sets are used to turn off the gadget after pressing the off button -
no confirmation "your phone is about to shut down, are you sure?", no second thoughts -
just kill all?
hopefully it's just some setting somewhere...
Originally posted by trebor View Post
Wow, it's your product? how many PCB layers? the production? the development?
i want to do something like that too? i would like to write an article about this (paper magazine)...
Got a PM from Dizet asking for a TWRP port.
Here it is - https://www.freak-tab.de/abdul_pt/Al...2.8.6.0_H3.img
He tested and it's working with one thing left to fix, External SD isn't mounting. If someone could edit this image and correct it great, or else provide the mount point for the External SD
Originally posted by abdul_pt View PostGot a PM from Dizet asking for a TWRP port.
Just had it confirmed by a friend that the mount point is /mnt/extsd
Hi to all
There are some nice H3 boxes like Zidoo,Draco,Sunchip,Beelink.We must to check which SW is the best.
I think thet Zidoo have best SW,but they have some stupid system which check your MAC address in order to use WI-FI.Can someone to remove thet stupid thing?
Zidoo have the best verified Antutu,CF-Bench and 3D mark.
If someone want to try Sunchip sw i will send link via PM.Last edited by plasma; 07 August 2015, 21:48.
Originally posted by plasma View PostThen,how you use it????
I do not need wi-fi,but there is constant massage on screen and I can not see nothing on tv.
I can not to remove thet activation massage from my desktop screen.
There are currently 2138 users online. 0 members and 2138 guests.
