Beelink X2 H3 box
TRIGTOP
1º when the kodi fixes? did you see the zidoo source code? ( https://github.com/zidootech/zidoo-kodi-14.2 ) give that to the allwinner engineers... they only need to remove the protection(android_main.cpp, AndroidFeatures.cpp, AndroidFeatures.h) and i think they can port it to kodi 15..
2º i have here 2 apps from 2 tv providers(IPTV) from my country that simply wont show the channel image, im going to try to give you a logcat.
Originally posted by TRIGTOP View Post
Hi rudolfo,
Passthrough hdmi audio playing a vedio (30Mbps 1080P 30fps mpeg2 dts) is ok. I will check more vedios and SPDIF.
The next version will fix the problem that SPDIF be switched to HDMI after reboot.
Thanks your valuable message.
Originally posted by kaufman View PostHi all, I have the TRONFY X2 box (which I'm guessing is based on the Beelink X2).
I have successfully updated the firmware to the last one posted here (v106) which has given me a true 1080p GUI and picture but I'm still having issues with audio passthrough in Kodi. I have tried the preloaded 14.2 and the newer 15 versions of Kodi (also the dev 16 version), Vidon Xbmc, Spmc and all of them have problems with audio passthrough.
On the 14.2 versions I can get passthrough with DTS solidly but the video stutters slightly with mkvs.
On the newer 15 versions the videos are fine but the DTS track keeps losing signal with the receiver.
With no passthrough it's fine just outputting in 2 channel pcm stereo.
I have set the audio passthrough in the X2 box settings to HDMI and SDIF, changed box resolutions, different HDMI/Ethernet cables and tried every type of config I can think of in Kodi (adjust frame rate, advanced buffer settings for low powered devices etc) all to no avail.
My reciever is a YAMAHA RX-671 and I have BT Infinity with 75MB/s dl/.
It's so frustrating!! Just can't get the thing to work properly with audio passthrough.
Sorry. Big bug, I will give a reply.
Thanks greatly.
Great.
TRIGTOP
Here you have the logcat... the name of the apps "pt.nos.iris.online" and "pt.vodafone.tvnetvoz".Last edited by superceleron; 07 March 2016, 04:03.
Can anybody say what is the configuration of the USB cable that must be used to upgrade from the PC.
I have a USB Type A male both side and it's not working.
Maybe somebody can share the OTA version for local upgrade."Rock more than music it's a way of living"
Tablet RK2918 - Yifang M900HC 8" JB 4.2.2 Oma
Tablet RK3026 - Yifang M7100KLD 7" JB 4.2.2
Tablet RK3066 - Yifang M7000 7" JB 4.2.2
Tablet AML8726-MXS - Yifang M7000NBD 7" - JB 4.1.1
Phablet Samsung Note 3 - KK 4.4.2
Cell Phone Samsung GT-S5760M - JB 4.0.3
Originally posted by DaremoS View PostCan anybody say what is the configuration of the USB cable that must be used to upgrade from the PC.
Just install a software Phoenixsuit in your PC. Two notes: the USB port nearby power supply socket is used as update port ; before insert usb cable and power on ,please pressing the update key continuously untill PC recognise the device. thanks.
Ok i just cleaned and builded zidoo kodi source code and is working 100% fine on my own rom build.
Tomorrow(5:40AM now) i will make a video and post it on my youtube channel comparing the 106k4 and my rom build(based on the 106k4).Last edited by superceleron; 17 October 2015, 14:07.
Originally posted by superceleronOk i just cleaned and build-ed zidoo kodi source code and is working 100% fine on my own rom build.
Sent from my GT-I9190 using Tapatalk
Originally posted by komicar View Post
I just saw your video and it looks fantastic. Tnx for hard work.
Allwinner really should invest more making their sdk a lot better, because as it is now.... really not good...
The chip is very good, but the lack of good software is making it look bad, btw wifi on this device are not good... HW design flaw? looks like it...
Tomorrow i will rls the rom after finish some things.
There are currently 2515 users online. 0 members and 2515 guests.
