Beelink X2 H3 box
Originally posted by nanosec View PostI have a unit that refuses to power on. It's an red/orange light and does nothing. Is this a corrupt rom issue or something else? I have not flashed any custom roms onto it, except for the update Beelink pushed through yesterday or the day before. Factory reset doing nothing.
Do you means that you had just accepted OTA update ,and then fail to boot? After accept OTA update it will download image and reboot into recovery mode to update , and then auto reboot to enter system.which step says failure as your remember ?
It seems software not works. Need an USE A-A male cable to update.
thanks
Originally posted by kPATm View PostTried the 106k4 img and it flashed after lot of attempts. But the box refuses to switch on. It has done this a few times after a flash with different img's. This was also the reason I flashed the box in the 1st place.
with USB cable or TF card or U storage or OTA? Does the device fails during the update bar and auto reboot severy times ?
Sorry
Try installing the VPN dialogues APK and try your VPN service again.
Originally posted by kPATm View PostThe only way I can update is via the USB cable it seems.
90% of the time I get a "Burn firmware failed" message
The box never reboots when I have a successful flash. I have to remove the power cable then try and reboot manually but that hasnt worked either?
I was playing around with an X2 the other day and also found that after a flash using the SD card the box would invariably not power up afterwards and that I had to remove the power cable and let it stand for half an hour before it would boot up correctly.
I also encountered the burn failed message a couple of times, so it it a little hit and miss.
Flashing with the cable does work though once you go through the correct process, although sticking pins in little holes in the vase of these products is a pain at times and there should be an easier way, or at least better positioning of the reset holes.
Originally posted by kPATm View PostI think I may try and flash using the method mentioned in post #78
The thing concerning me is that I cant get the box to turn on so how do I flash via Micro SD?
What you will likely find is that if you are able to successfully create an SD card flashing image that when you pop it into the X2, it will magically come to life upon it's detection.
I found that on more then one occasion where the box didn't look as if it wanted to come to life.
Can any of the images from here http://www.tabletexpress.com/tablet.html?brand=272&p=3
be used to flash the X2?
Originally posted by kPATm View PostCan any of the images from here http://www.tabletexpress.com/tablet.html?brand=272&p=3
You may well find that some of the driver components will be different and therefore find functions that do not work.
They do however have a Karaoke option in the top right hand corner where is says 'Sing in'
Either that or they have a novel new voice activated sign in option.
There are currently 2204 users online. 0 members and 2204 guests.
