Beelink X2 H3 box
    Thanks to @gearbest
    This is the links to download the firmware 204k4:
    root system: link: http://pan.baidu.com/s/1pKbYAiZ password: 4ecs
    t-card update: link: http://pan.baidu.com/s/1dEq6a8x password: ob5c
    root tools: link: http://pan.baidu.com/s/1pJZWHwJ password: h76v
    Source message:
    http://freaktab.com/forum/advertiser...647#post550647
    Beelink X2 and Nexsmart D32 for now!!!
      reinstalling the app didn't fix my problem
        Sorry it did not fix that for you .
        I force stopped all the video related apps in Settings -> Apps , and uninstalled the YouTube app, before downloading the YouTube app again from the play store.
        Maybe you need to do that ?
        D.
          The launcher on my MK808B is more user friendly than that on the X2. Are there other launchers available for the X2 ?
          Also , there seems to be no way to stop apps other then to enter settings to force stop.
          When i use my wireless Keyboard to switch apps (ALT + TAB), all the apps that I think I've closed are still offered as options.
          So it seems like they are still open and operating in the background.
          ( A user manual would have been an asset ).
          Great box otherwise
          DenisM
            i think i can't uninstall youtube app, just disable it
              I installed google play services to be able to use Youtube, but now everytime I turn on my box I get a notification about google play services error.
              Does anyone know how can I fix it or why am I getting that error?
                that's a very common error, just clear cache, reboot multiple times
                  How can i install apps in an external sd card ? Is it possible in this tv box ?? Any help ?
                    How do I clear the cache? Thanks in advance.
                    Nevermind, found how to on a internet tutorial, will try it when I get home.
                    It worked, thanks again
                      layer
                      You're right - it can't be uninstalled ! Only clear data, clear cache and disable. Now I'm puzzled
                      I was sure I had uninstalled it !
                      I did install an additional youtube app from the play store - didn't like it and then uninstalled it.
                      Maybe you can uninstall from within the play store , having installed it from within the play store ?
                      DenisM
                        >ref #505 above - Are there other launchers available for the X2
                        I did install Nova Launcher from the play store, but it's not any more useful than the existing launcher.
                        Is there any one that you would recommend ?
                        D.
                          Does anyone know what camera BeeLink X2 supports? I tried couple USB webcams but "failed to connect camera" when I clicked on "CAMERA". I am thinking to use "Skepe" with BeeLink X2. Thanks.
                          Wushu2266
                            I'm using a Logitech C170 . Works perfectly with Skype
                            DenisM
                              DenisM
                              Thanks DenusM, I do not have a Logitech C170, at least that I know it works.
                              wushu2266
