Beelink X2 H3 box
    Originally posted by Monalis View Post
    In the adupsfota folder was only ONE file - the last (4th) update!
    In a few hours I'll upload the 3rd update.
    I have many files in adupsfota folder for the 203k4 update and this files are the package for the installation.
    Look lhe screenshot:
    And to install the newest firmware we need the all package.
    I think i know why i can t upgrade with this file. Because this file is lhe last upgrade 205k4.
    And we need first upgrade with the files from the upgrade 204k4 (i think is the 3º upgrade that you mentioned). This image from your post show the size and is more than the other upgrades. 78,86 Mb and i think this is the size from adupsfota folder or update.zip file.
    When you can upload the 3º upgrade (204k4) we should test.
    Thanks Monalis
    Beelink X2 and Nexsmart D32 for now!!!
      1. Actually, from what I can see now, I'm on 205k4 version
      I can see an update.zip on adupsfota folder.
      I think it's only the last one.
      You can find the file attached to this post
      update.zip
      * on my other X2 box I did not yet apply this update, so I might have the "last but one" update.
      I'll check it in 10 hours, now is the middle of the night here.
      2. I use 4K 30Hz resolution on my LG UHD TV and is reported as such by the tv.
      3. For AC3 files to play in MX Player, you need a custom codec.
      Download the file from http://goo.gl/U85k5K with your Box browser and start MX Player.
      It will autodetect the file.
      Detaile info here: http://goo.gl/JtCFBj
      I think you are right - I tried installing this on 203k4 - which is as far as the online update system seems to want to take me.
      It complained about the update file - seems to report that it required something else - So I think it is checking that I have 204k4 installed - and of course I dont have that.
      So pretty sure your file is the 205k4 update!
      If you can catch 204k4 and make that available that would be wonderful - cant think why their online system wont update me - I have flashed back to 106k4 several times and the online updates take me up to 203k4 each time then stops...
        I think TRIGTOP firmware update is not the same as the official one, so if you flashed TRIGTOP his latest version is 203k4 I think.
          Pretty sure I had flashed back on the original 106k4 release - but now I am not too sure - Will download the release that is on the gearbest site and re-install that and see what happens.
          The gearbest release should be the 'official' firmware.
            I've tried my other box today.
            It's 204k4, BUT it autodownloaded the 205k4 update, even if I refused it
            So I cannot give you the 69Mb 204k4 update, sorry
            BTW, I have Kodi 14.2 Git:2015-1-16-744418e (compiled: Oct 16 2015)
            It does not scan the database!
            I can only use the File option.
            I've reset the DB, but doest not work!
            if I put the latest Kodi, I lose the HW acceleration?
              Ok no problem... @Monalis
              But tell me something, your box come with 204k4 firmware?
              If not if came with 203k4, you should update and download to 204k4 and next shut off the internet connection and should able to copy the files.
              Or if someone can do that.
                update.zip
                Will AC3 and DTS continue working on a receiver with passthrough with the custom codec on MX Player?
                  the update.zip link do not work
                    i have my beelink x2 with 205k4 and i can't view videos in youtube app(says click to try again on the video area), is this normal?
                    i think i have made more than 4 updates since i have it, youtube never worked...
                      The original version was 201k4
                      I really do not know, but it easy to try.
                      If you delete the downloaded external codec, MX Player will not use it.
                        Monalis thanks for your help.
                        Can see one more thing in the folder system in the root... You have a file called build.prop open like txt and in the bottom copy and the paste the information of the OTA.
                        Should help to understand why some people have the update and some people no.
                          OK - Got the 104k4 img file from gearbest - I assumed it to be a factory image.
                          I flashed the x2 with this version.
                          It now just reports that the box is up to date and does nothing else - I am quite stumped!
                          Does anyone know for sure if the TRIGTOP software releases actually supported auto update?
                          So that would make his software a completely different branch to the standard software?
                            Is there anyway to do an image on the memory of my box for you ?
                              you could make a copy of build.prop it is in device/system folder
                                I talked with superceleron and the only way to make a backup of the system is with a compatible TWRP (Custom Recovery).
                                Or with a app that can do that... i made a serch and i found a app "Flashfy" but i dont have the knowledge if work to make the backup.
                                It's just need the full backup of "SYSTEM" and "KERNEL" and "BOOT".
