Beelink X2 H3 box
    Originally posted by komicar View Post
    No need to hurry, release when you have time. You did not mention audio sync in Kodi, is it better?
    Hi Komicar and everyone,
    I have some DTS and Dolby videos, such as "1080P.MPEG2.DTS.girl(37.3Mbps & 29.970fps).m2ts" and "1080P.MPEG2.AC-3.girl[34.3Mbps & 23.976fps].mkv". Playing these video with new kodi , the result of audio passes through to SPDIF or not is same, no stutter.
    With 104k4 image it will stutters badly when switch to "audio pass through to spdif" .
    About this problem, please help me check it in the new image.
    Otherwise, the new Kodi seems can deal with 4k 50Mbps video decode.
    One bug we are doing is that the vedio will falter and is not fluent when a transparent windows floats on it, such as file list after press return key . After the floating windows disappeares, the video playing will be smooth.
    Welcome and please help to bring out advice for the new born kodi.
    thanks.
      I would like to help, but unfortunately my amplifier only have analog inputs, not digital. Someone else here is probably able to test it.
        Has anyone noticed, that there is not way of turning the device on, if you don't have the remote control ? The power button on top does nothing (at least in my case). The light just stays amber.
        So, to use the device, I need to first turn it on from the remote, and then do whatever I want to do with the mouse/keyboard.
        What will happen if the remote is broken?
        EDIT: My mistake. It works, just not every time. I guess it's a problem with my particular device. Moderators, you can remove this post.
          I updated my devices yesterday. I noticed that you are not able to update the binaries in SuperSU. How do I fix that? It isn't effecting anything right now, but I would like to have this working.
          The new Kodi is working great. Thanks for the update.
          Has anyone heard of Emby? It is much like Plex.
          They have an app for AndroidTV. For some reason, on this device, the back and home button on the remote does not work for this application. I contacted them, and they stated they are using the call BACK to go back to the main screen within their application. KODI's back button works great, I would just like to use their app to watch videos instead of KODI. Anysuggestions on how to fix that?
          Thanks.
            The cheapest place I've found for these boxes is Everbuying, they have the Beelink X2 for $30.62 (including free shipping).
            http://www.everbuying.net/product933857.html
            Does anyone know an even cheaper place?
              Hi Kamelot,
              The power button on the top of the case is used for power on. After insert power supply and then press the button on the case , the led will turn to blue from red and boot into the system.
              If the button is not ok ,you can turn to the sales person.
              thanks
                Dear all,
                system update to 202k4, clicking "setting"--"update"--"online update" to update with OTA.
                for 201k4 bug: no root and add netflix patch
                thanks.
                  Well. I received mine a couple of days ago and havnt really had time to mess about with it yet. Turned it on just now and all I get is a red light. It wont turn on I have tried numerous resets and plugging/unplugging cables. I think its a goner :-(
                  Time to get on to Gearbest I think
                    I managed to get the box updated with superceleron's image BUT I cannot get a picture on any of my TV or monitors. The blue light blinks when I press the remote buttons so I presume the box is actually on???
                      Hello,
                      VPN doesn´t work. Did it happen with previous roms as well? I would actually need it.
                        What you Tv says? out of bounds like a unsupported resolution?
                          MY TV says nothing just a blank screen?
                            Originally posted by Xavier0 View Post
                            Hello,
                            Try installing the VPN dialogues APK and try your VPN service again.
                              :/ did you try the 106k4? and use the "1/a" on the remote?
                              if that don't work i think your device have a damaged hdmi port!
                                Will give that a go. Cheers
