Beelink X2 H3 box
Nowhere im still working on it!
Wifi with tweaks around 30mbits(without it around 10...)
"WIFI with tweaks" would you give your secrets?"Rock more than music it's a way of living"
Tablet RK2918 - Yifang M900HC 8" JB 4.2.2 Oma
Tablet RK3026 - Yifang M7100KLD 7" JB 4.2.2
Tablet RK3066 - Yifang M7000 7" JB 4.2.2
Tablet AML8726-MXS - Yifang M7000NBD 7" - JB 4.1.1
Phablet Samsung Note 3 - KK 4.4.2
Cell Phone Samsung GT-S5760M - JB 4.0.3
Originally posted by Wurstpelle View Postwifi is purely based on positioning. The Antenna is printed on the circuit board. With the device standing on its side I get constant 60+ Mbit oppised to less than 15 when its standing flat.
I was a bit frustrated with the wifi performance so I went inside the unit, disconnected the printed WIFI antenna, installed a u.fl connector and now have an external rp-sma antenna. Just needed to drill a hole in the case to pass the cable through. Works great. But wifi is still a bit dodgy when trying to use Kodi to stream video from my NAS so I use ethernet for that. I use the wifi mostly for miracast.
I am new here. Just did a firmware update on my BeeLink X2, it is looking good. Couple questions: 1) how to do backup using PhoenixSuit? 2) is it possible to update to the latest version of Kodi? 3) where can I download the current version of Kodi Helix 14.2 just in case if I have to go back? 4) Can I do a restore then it will be back to version 14.2 if I know how to do a backup first? Thanks.
Originally posted by wushu2266 View PostI am new here. Just did a firmware update on my BeeLink X2, it is looking good. Couple questions: 1) how to do backup using PhoenixSuit? 2) is it possible to update to the latest version of Kodi? 3) where can I download the current version of Kodi Helix 14.2 just in case if I have to go back? 4) Can I do a restore then it will be back to version 14.2 if I know how to do a backup first? Thanks.
Thanks bibbit for your input.
I did install Kodi V15.2, but it did hang up when installing from zip couple of times. When I took the update 4.4.2 KOT 49H 20151105 test-keys, it reloaded Kodi V14.2. So I left it alone.
When using PhoenixSuit, I never able to see it connects to X2 except doing firmware upgrade.
Can someone explain why I am getting too big of image on one TV but not another, they both are 1080P TV? Also I am using Kodi with Raspberry Pi on the same 2 TVs, the image on both TV look the same. Kodi with Raspberry Pi is setup for 1080P display too.
Hi guys. First time poster but long time lurker here.
I want to buy this device but curious about h265 capability. Can it really play h265 encoded 1080p content ? I know 10bit is not possible but normal h265 1080p would be great actually. And do we need to use kodi to play these 4k or h265 files or can we use mx player too ?Last edited by patientx; 29 December 2015, 21:38.
Hi guys, i bought a air mouse for my Beelink x2.
(http://www.aliexpress.com/item/2015-...356455351.html)
When box is on, there is no problem control the box with the mouse. I can turn off the box with air mouse remote. But when I turn off the box, I cannot turn it on with air mouse controller, I have to use an original remote for that. Anyone can help how can I turn on my X2 with this air mouse remote ? Thanks a lot guys !!!
Originally posted by dextersk View PostI cannot turn it on with air mouse controller
I find it takes so long to boot up, I just leave it on and turn the TV off. Or you can press the button on top.
It uses an extra 2W in idle vs standby, (0.5A, vs 0.1A ) so not terrible.
Originally posted by patientx View PostCan it really play h265 encoded 1080p content ?
I find playback in Kodi (stock firmware) quite jerky on this device. It is very noticable in slow-pans such as demo clips, or the GoT opening sequence.
But the TVMC version of Kodi works fine.
Should I delete the version of Kodi that came with the X2 and download a vanilla version from the Play Store?
Originally posted by Wurstpelle View Posthas anybody managed to get Netflix running with 5.1 sound?
On Android?? Possible, but not on the X2. You'll need Lollipop at least.
There are currently 2645 users online. 0 members and 2645 guests.
