Beelink X2 H3 box
Is the resolution switch really needed? You can do it from the system menu easily enough, once I have my box in what ever resolution I want I don't change it again. By all means start in 720p for max compatibility but the res change from the system menu should work/stick.
@mino the X is for delete, you need it if you don't have a hard keyboard.
I think resolution switch isn't needed too. You are right Hairybiker about X but delete button is in every sw keyboard, and may be replaced (if it's realy necessary). Notification can't be opened any way. Then there is blue "APP" button which do nothing with my box... And if sombody will have black screen because of bad resolution, maybe he will try to pressing all buttons and with "app" button it will be only 4th try
Originally posted by bluesmanuk View PostNow that the Kodi source code for the Zidoo X1 has been released perhaps Trigtop would like to compile the apk for use on the X2?
I preffer official release of Kodi, no matter what. If Zidoo managed to solve the sync problem (does it?) smart move is to send patches to Kodi developers, not to depend on obsolete platform. Thats my 2 cents anyway...
Originally posted by komicar View Post
I am not sure that would be good for us. Version 14.x of Kodi is already obsolete, when 16.0 is in alpha stage.
The advantage in the mean time though might be the opportunity to have something stable and more useable until what Zidoo have done can be integrated into main Kodi.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by Almocho View PostHi guys, does anyone have problems to install new addons or repo in Kodi with this box?
Just press Home button, go to the Settings/Apps/Kodi and stop it. After that Kodi works fine, even repo is there. No idea whats the cause, but I suspect to some bug in Kodi.
Except that, not a single problem with stability and speed. If they ever manage to fix audio delay in Kodi, this will be best media player. Big if...
Few times, when I was installing some repo, Kodi get "freezed", but Android was stile alive and kicking.
Except that, not a single problem with stability and speed. If they ever manage to fix audio delay in Kodi, this will be best media player. Big if...Last edited by superceleron; 18 September 2015, 18:07.
Hi Guys
Has anyone tried this box with Plex, the only way I can get it working is to use the External Player option in the Media Profile. I also have a R68 Tronsmart and everything worked fine out of the box with that but I could not play video's with the Beelink X2. I'm using MX player as the External player.
Hi, if somebody have problem with audio sync in kodi, this helped me:
Open any video that has audio playing.
Bring up the on-screen-display and select the audio options.
Select Audio offset and then adjust the audio until the delay is corrected.
Back in the OSD audio settings, scroll down and select Set as default for all videos.
It is from kodi wiki.
No I have default audio delay in all videos. 200ms is just right in my box.
Hey all - need some advice: I'm trying to install/configure PIA VPN client on these roms (tried this with 103, 104, 106). After plugging in my login details and config info android usually prompts with a message window stating something like "this app has the ability to intercept your IP traffic"....which is all fine and good except that on these ROMs the message doesn't appear on top...and I have no way to get to the message window. I know this message is just waiting for me to accept it, but I can't seem to get to it.
Any thoughts on how I can navigate to this window??
(you'll see what I mean if you install Private Internet Access VPN on a phone for example, and plug in some login info (I think fake info would work too)...then android prompts with a system message...then if you do it on the X2 ROMs I think the launcher or some app is preventing the message window from being on top).
There are currently 3741 users online. 0 members and 3741 guests.
