I'm currently using Draco H3 with its 1080p firmware and SPMC 15.0.
Beelink X2 H3 box
Originally posted by amd7674 View Post
What is your exactly problem... playing 1080P with HD Audio 7.1? I'm finally happy with my setup (other than poor wifi) and I can try to reproduce your issue(s) on my device.
Originally posted by whatabody View Post
Any build of Kodi, Spmc has the same problem even if I use wifi or cable so I ruled out that. most of the streams have a jump or skip every couple of seconds, the audio is perfect to me it seems like a codec issue. the x1 had the same issue but they released a fixed kodi, I have tried to install that version but it starts up with a black screen then goes back to the desktop. my box is the CS199
Can Draco H3 users PLEASE post your results from running tests from http://speedof.me site? Maybe it is my router setting causing very poor wifi performance.... I'm getting around 2.5mbps results...and 4mpbs using my nexus 4 phone (dual band wifi)....
Are you taking about 1080p video streams with HD Audio 7.1? What do I have to do to reproduce the issue? I'm more than willing to try it on my draco h3 box. Just please give more detail what and how to do it :-) Did you to play impacted files off SDHC card?
might try a flash from the x1 as it has the same problem
Originally posted by budgetgeek View PostCan the Draco H3 conversations move to a dedicated thread?
http://freaktab.com/forum/tv-player-...for-prime-time
1080p, 720p, sd audio 2.0 I tried mad max in genesis and that seems fine at 720p. in phoenix addon1080p, 720p, stutter any live stream such as sports from many sources stutter, I have other tv box CS918s and they all work perfect. one thing I have noticed is when I change the box to 1080p and restart it starts up 720p.
http://freaktab.com/forum/tv-player-...doo-x1-release
Try maybe different settings in advancedsettings.xml http://kodi.wiki/view/HOW-TO:Modify_the_video_cache
Originally posted by mike808 View PostUpgraded to the new firmware today, and it looks good, i miss the windows 8 style UI however, everything else looks good, it's rooted, I was able to change the lcd density to 240 to make the text and icons look proper after setting resolution to 1080p. Also, the first thing I did was to uninstall Kodi and install SPMC 14.2 which works great, I don't have any problems like skipping etc., however, I'm strictly using SPMC. Downloaded a 4K sample video Timescapes and it played flawlessly in SPMC, same video doesn't play in my all black MxQ box, however, MxQ is great for anything upto 1080p as it plays it flawlessly.
Definitely a good box that can do 4k effortlessly will buy more of these, however, I would like to see the Mbox Style UI like other boxes (windows 8 look), I backed up the Mbox Launcher and settings from my MxQ box and tried to install it in X2 however, the installation failed.
My MxQ box is true 1080p as well and the firmware included the MBox Launcher which works great with it, I'm use It can be done on this box as well, so please try to include MBox style launcher in the next release. Thanks.
Dear Mike808,
OK.
Better late than Never. Beenlink X2 H3
Handy Box for the Price and Snappy
Just a few Images for those interested
Crazy price for this little beast.
http://goo.gl/p8vS5D
There are currently 2246 users online. 1 members and 2245 guests.
