Tronsmart MK908 Android 4.1.1 - Finless ROM 1.4
Originally posted by Agustin47 View PostIf my work benefits you and you want to help out the cause, feel free to
http://www.hoaby.com/android/donate.gif
Originally posted by JugsteR View PostWould this work on a CX 919 as well? I think they have similar hardware.
Signature? Signature!If my work benefits you and you want to help out the cause, feel free to
Originally posted by hoabycsr View PostUnderstood. Thanks so much again! Do you have a post that describes working with the boot.img in detail? Been meaning to learn more about that.
Originally posted by Finless View PostIf my work benefits you and you want to help out the cause, feel free to
Originally posted by Finless View PostYes I know the 4.2.2 BETA Netflix does not work but as your table shows it does work on my 1.5 4.2.2 ROM.
As for camera. My C310 camera works fine on my 1.5 ROM.
I registered here to express my thanks for your great work.
You mentioned that Logitech C310 camera works fine on your 1.5 ROM.
Could you tell me how to make this work because I can only use my c310
as a microphone but there is no video on skype.
Thanks in advance.
usi
Originally posted by pioneerf2 View PostHi everyone, newbie here.
Sorry for bumping a month old thread.
For those of you having jerky video problems and mouse movement solves it, try this trick, hope it helps
Download setcpu or something similar and set the cpu as
Min- 1.2 ghz
Max- 1.6 ghz or whatever is the max.
Please report your results
I installed this ROM along with the Strauzo kernel for the MK908.
Everything worked excellently. The only problem I have is that the display seems to be a little larger than my TV allows. That is, the display stretches beyond the boundary of my tv. Do I need to reflash my stick or is there a setting I need to change. It's definitely not an issue with my TV and no setting on the TV makes any difference. Cheers
Originally posted by TheFonz View PostI installed this ROM along with the Strauzo kernel for the MK908.
Sent from my Xoom using Tapatalk HD
any TWRP capability?
Hi Bob, I was curious if you know if TWRP works on these devices? I am familiar with using TWRP and how it accepts commands from goo manager on HP touchpads running android. So I am curious if it is possible to use it on the MK908. I just received mine and I am waiting for a few more parts to make the final jump. Thanks for all your work on this device.
Re: NEW - Tronsmart MK908 Android 4.1.1 - Finless ROM 1.4
Originally posted by kmellon View PostHi Bob, I was curious if you know if TWRP works on these devices? I am familiar with using TWRP and how it accepts commands from goo manager on HP touchpads running android. So I am curious if it is possible to use it on the MK908. I just received mine and I am waiting for a few more parts to make the final jump. Thanks for all your work on this device.
If it had, it'd work.
There are currently 1845 users online. 0 members and 1845 guests.
