I've been able to mount de boot.img and system.img and can't find the file you talk about, now I'm trying to mount kernel.img to search for it...
MK808-B (original) JB 4.2.2 Official - Finless ROM 2.1
Noo dslr dashboard, no adb
(EDIT: FIRST PROBLEM SOLVED:
//I'm new to android.
With ES Downloader found code.google.com/p/ and my app. Installed fast and good. Works fine with Nikon D5200 via usb through vnc.
THE PROBLEM WAS
//1) I wanted to install dslr dashboard with google play. But the software is said incompatible with this device. So I tried to install it with the browser. It accepts MK808b, which was the original rom and is registered with my account. But it doesn't accept the spoofed Samsung device. )
//So I've changed back build.prop to the original one. But the new device "T-mobile Mk808" is still incompatible.
2) "adb devices" doesn't recognize my usb-stick in windows 7. (mtp-is enabled in build.prop) The system of Windows 7 accepts my stick after a change in the .inf-file of the google-driver. The google driver is installed and reported as "working". But "adb" doesn't see the device.
For the moment I am working with wireless adb. But my Nikon wu-1a needs an own wireless connection.
THE SECOND PROBLEM STAYS.Last edited by gerdich; 06 July 2013, 15:56.
noobish question about this ROM
Devs,
I've had my mk808b since around the first of the year-I'm running mk808b_v401j2 2013-03-18, with clockworkmod recovery installed. Is there any way I can flash this rom from CWM? I have soft bricked this device a few times now, mostly from uninstalling "uneeded" system apps that were really needed, or other experimenting, and CWM+nandroid backups have saved my ass everytime on this and many other devices, I hate flying without my safety net. I have figured out how to make it boot into recovery using a paper clip while powering on, etc. Will CWM still be there after I use the PC tool to flash this? Or, can I just do the rename cwm.zip to update.zip on the SD card and boot like I did before? I'm so used to cyanogenmod on phones and tablets nowadays, and I play with so many devices I can't always remember how I did something a few months ago. I checked http://androtab.info/clockworkmod/rockchip/rk3066/ and the CWM there is the same I already have. Thanks in advance, and sorry if you have already answered in other posts, just didn't see it all spelled out like this.
Re: NEW - MK808-B (original) JB 4.2.2 Official - Finless ROM 2.1
In other words, flash from pc only system, boot, misc and kernel from pc. This should keep your sdcard, recovery and parameters file like it was before the test, the apps you installed will be there too, so no need to reinstall, I allways suggest after reflash system wipe cache and dalvick cache, and some times wipe data and loose your apps installed is necessary too.
NAND disappeared
Originally posted by leolas View PostIf you use pc to flash the device, only need to unselect bootloader, parameters and recovery, and dont erase idb(this will erase your full nand).
leolas
Originally posted by gtaber View PostThanks, I tried it like you said, and it seemed to work great at first, but my NAND wouldn't mount at all after-tried wiping dalvick cache, then wipe cache, and then even a factory reset, still no nand. Couldn't get it to mount, the "mount NAND" option in settings-storage stayed grayed out. So I reflashed with the full set of check marks, 1080p boot and kernel, 2GB parameter, verified NAND was mounting correctly, then put the CWM.zip on a SDcard, renamed it to update.zip, and when I put the card in the stick, it prompted me to install the update, rebooted to CWM, and now I have my clockworkmod recovery back, and made new backups. It did keep all my apps at first since I didn't wipe IDB, but most were running from the sdcard, which was the nand, and wouldn't work anyway. But everything is good now, and the 1080p looks great. I'm used to reinstalling apps, that's half the fun of playing with custom ROMs :_) Thanks for all the work the devs did on this ROM :-)
Originally posted by leolas View PostSome times erase the full nand is the only option that works well. For it, i suggest to make the backups in an external sdcard.
leolasonce I get rid of a device, I have to remember to delete all the crap it generated while I owned it.
Does not boot?
I've tried to flash with this ROM but when everything is done, i plug it into the TV, the device becomes stuck on the boot screen (with the black android etc). The 4 circles on the bottom does not move like its suppose to. I tried to reflash it and etc, but it does not seem to work.
I have the 808B, and flashed the older finless roms before and it worked.
Can anyone help please, thanks!
Originally posted by sheepe View PostI've tried to flash with this ROM but when everything is done, i plug it into the TV, the device becomes stuck on the boot screen (with the black android etc). The 4 circles on the bottom does not move like its suppose to. I tried to reflash it and etc, but it does not seem to work.
I highly recommend ALWAYS make a nandroid backup of your working device before trying to flash anything new, it has saved my ass many times on many different android devices.
THE PROBLEM WAS
as it was my last resort
(rk batch tool didn't see my dongle), when I launched the Tool, it detected the dongle in loader rock usb mode (not mass storage), so I skipped the driver installation steps.
I successfully erased NAND with your tool, but when I tried flashing ROM, my windows virtual machine (ran it in VirtualBox) crashed - time after time, after first 52K data written. Any hints?Last edited by rerere; 16 July 2013, 18:52.
There are currently 3474 users online. 0 members and 3474 guests.
