X2 H3 BOX images customized for Freaktab.
    hi i looking for version:X2_202K4 for BAD RED LIGHT version o other, to no need power button..... any body can help me?
      after update, my wifi no working.... just grey on turn on button to activate wifi....
        Originally posted by TRIGTOP View Post
        Dear all ,
        new images.
        version:X2_203K4
        based on:202k4
        OTA open time:20151105
        features:
        1, old features: 1080p UI, allwinner LOGO, root,720p60 default resolutions and so on.
        2, for bug vpn connect fail on 202k4.
        3, Auto power on without requirement pressing button after power be inserted.
        For USB cable image link: https://mega.nz/#!1xZnWKyI!goV_KbZjd...2AfK8AmA_MjQMc
        based on:202k4
        release time: 20151103
        For: RED light and fail to power on board.
        features:
        1, power on directly after insert power supply , no need to press the button.
        2, 720/60 resolutions, MBOX logo.
        For USB cable to update. image link: https://mega.nz/#!ooxkAIKC!bT9RYSycd...wgsDy4ktR2e2OY
        version:X2_202K4
        OTA open time: 20151026
        based on:201k4
        features:
        1, for 201k4 bug : root ; and add netflix patch.
        just OTA update,no download link for it is a complement to 201k4.
        version: X2_201k4_20151020
        based on:106k4
        features:
        1, old features: 1080p UI, allwinner logo; 720p60hz default resolutions; key"1/a" on remote to switch resolutons;
        2, selection of "audio/ pass through/ SPDIF" will be saved after reboot;
        3, revised kodi 14.2 based on ALLWINNER H3;
        4, some trival adjustments, such as remove power off pop-up message, built allcast for airplay.
        download link:
        just for USB cable update: https://mega.nz/#!C49yFQSa!k7MWJm73F...LOMb09UuVD1GVo
        update method:
        2, USB cable download
        tool: PhoenixSuit_EN_V1.0.8.exe. Please read its user guide "PhoenixSuit user guide EN.pdf".
        steps1: download update_X2_V103k4.img and phonixsuit. prepara an A-A male USB cable.
        steps2: install phonixsuit on your PC (win7 or other OS) and open it. Locate update_X2_201k4.img in the download page.
        steps3:Connect USB cable to PC.
        steps4:On the bottom of the BOX and near the Power connector, there is a hole and an update key inside. Pressing the key through the hole with a pin ,and then plug the another side of the USB cable to the BOX USB port,the one nearby the power. The usb cable will supply power and the box will enter update state. Then PC will pop a note ,ask whether to earse the data.Loose you hand pressing update key and select "yes" and then download action starts.
        Cautions : this update method will produce a whole new system, all your old data will lose.
        all this firmware is to ap or realtek wif Realtek RTL8189ETV
        208k4 or 209k4 any body can share it????
        Last edited by herr_marechal; 13 April 2017, 05:33. Reason: i think better about this.
          Hi Dear, please show me SN number of your X2 box. I will share firmware with you then.
