X2 H3 BOX images customized for Freaktab.
    Dear all ,
    new images.
    version:X2_203K4
    based on:202k4
    OTA open time:20151105
    features:
    1, old features: 1080p UI, allwinner LOGO, root,720p60 default resolutions and so on.
    2, for bug vpn connect fail on 202k4.
    3, Auto power on without requirement pressing button after power be inserted.
    For USB cable image link: https://mega.nz/#!1xZnWKyI!goV_KbZjd...2AfK8AmA_MjQMc
    version:X2_202K4 for BAD RED LIGHT
    based on:202k4
    release time: 20151103
    For: RED light and fail to power on board.
    features:
    1, power on directly after insert power supply , no need to press the button.
    2, 720/60 resolutions, MBOX logo.
    For USB cable to update. image link: https://mega.nz/#!ooxkAIKC!bT9RYSycd...wgsDy4ktR2e2OY
    version:X2_202K4
    OTA open time: 20151026
    based on:201k4
    features:
    1, for 201k4 bug : root ; and add netflix patch.
    just OTA update,no download link for it is a complement to 201k4.
    version: X2_201k4_20151020
    based on:106k4
    features:
    1, old features: 1080p UI, allwinner logo; 720p60hz default resolutions; key"1/a" on remote to switch resolutons;
    2, selection of "audio/ pass through/ SPDIF" will be saved after reboot;
    3, revised kodi 14.2 based on ALLWINNER H3;
    4, some trival adjustments, such as remove power off pop-up message, built allcast for airplay.
    download link:
    just for USB cable update: https://mega.nz/#!C49yFQSa!k7MWJm73F...LOMb09UuVD1GVo
    update method:
    2, USB cable download
    tool: PhoenixSuit_EN_V1.0.8.exe. Please read its user guide "PhoenixSuit user guide EN.pdf".
    steps1: download update_X2_V103k4.img and phonixsuit. prepara an A-A male USB cable.
    steps2: install phonixsuit on your PC (win7 or other OS) and open it. Locate update_X2_201k4.img in the download page.
    steps3:Connect USB cable to PC.
    steps4:On the bottom of the BOX and near the Power connector, there is a hole and an update key inside. Pressing the key through the hole with a pin ,and then plug the another side of the USB cable to the BOX USB port,the one nearby the power. The usb cable will supply power and the box will enter update state. Then PC will pop a note ,ask whether to earse the data.Loose you hand pressing update key and select "yes" and then download action starts.
    Cautions : this update method will produce a whole new system, all your old data will lose.
    That is about time, you need to port the kodi 14.2 fixes to kodi 15.2...
    Did have a look on the logcat o posted on the other thread?
    Btw enable xbox360 driver on the kernel... and use my kcm and kl files...
    Its nice to see a factory giving support to their product for a change...
    Keep the good work
      Dear Superceleron,
      Great. you advice is valuable and I will try to considered it in the next version. thanks.
        restate one thing.
        About the new kodi, it seems to can decode some 50Mbps 4K videos, and the audio pass through to SPDIF is ok for the local dts and dolby 1080p video even 37Mbps code. please help me check it. Addtionally, an obvious bug we are doing, the video will falter and is not fluent when a transparent windows floats on it, such as file list after press return key . After the floating windows disappeares, the video playing will be smooth.
        15.1 kodi is on the way, for the new chip H64 and H3 too.
          ok some bugs,
          Root is broken...
          Btw AW codec still needs more work, you only got part of it working(see my rom and test it...) and you should put a option to enable it or disable it in the options and fix the aspect ratio menu...
          Still a lot of work in front of you!
            Originally posted by TRIGTOP View Post
            restate one thing.
            That bug is also present on the mediacodec on other chips, when the menu opens the video get very jerky.
            Btw the audio is total out of sync really around 5 secs
              Btw download the samples from here... http://www.libde265.org/downloads-videos/
                Thank You TRIGTOP .
                ​Thank You superceleron .
                Beelink X2 and Nexsmart D32 for now!!!
                  So, which rom is better at the moment? TRIGTOP or superceleron one?
                    Thanks TRIGTOP and superceleron. I love this box.
                      restate one thing.
                      Thanks for all the hard work. Kodi 15.2 final release is out with some fixes for Android. This will make better modified Kodi than 15.1 which has bugs with fast forward etc...
                      Sent from my GT-I9190 using Tapatalk
                        just discovered the update - thanks will post feedback soon
                          i have tronsmart h3 draco and cx-x3 box and now i got a x2, tried lots of firmware found the latest from tronsmart best, because the wifi is stronger and more stable on tthe x2, but remote is not working and the led is red with this firmware, is there a way to change that or port the wifi files and settings to x2 firmware?
                            Yes edit the sys_config.fex file and you can fix it , and boot to load the driver etc..
                              sorry but don“t know how to do that btw your firmware is also good for wifi perfomance just missing some of the remote controls like a1....... Thank you for responce and firmware
