X2 H3 BOX images customized for Freaktab.
    yes i know, mine is based on the 104k4 on that but only on that, all the rest is 106k4
    You can use the 106k4 kl files on mine
      There is a OTA update to 201k4. As soon as I turned on the box, a notice to update was received.
      the 201k4 is a BIG improvement.........
        yes is better but read the 1ยบ page... some bugs...
          Box just updated via OTA
          Was rooted before update and has now lost root making Reboot apps useless..Is this rom supposed to be rooted? If no how can I root box? Thanks
          Sent from my GT-I9190 using Tapatalk
            Do you you ppl read what i have wrote?
            Read the 1ยบ page... on post #5 i said root is broken and a lot of other bugs..
              Read the 1รฏยฟยฝ page... on post #5 i said root is broken and a lot of other bugs..
              Lol..Blind as a bat. Will wait for next update. .. What happened to the thread with your rom. It just vanished on my tapatalk. ...Will have to logon via pc
                is sticky
                  can someone help me troubleshoot my beelink x2? it was working fine then i turned it on today and i get a blue power light but no picture from the HDMI output. i have switched cables and tried different inputs and my other cdmi devices display fine.
                    well that is one of the problems on this device, sometime the hdmi just stop working... on mine only after i power off/and turn on the tv with the box on and connected to the tv...
                    See if that helps.
                      Netflix does not work correctly with this image. After about 20 second playback the picture gets distorted. Black and White with interference. I only see this on netflix so far.
                        Where do we find the OTA version of the 201k4 update?
                          Any idea when Kodi 15.2 for X2 will be released. ?
                            Thanks for your hard work with new firmware.
                            Unfortunately on this new KODI 14.2 audio passthrough dts plays ok (not stuttering as before) but the video still judders although it seems slightly better than it was before.
                            The stuttering I think is to do with the KODI hardware acceleration setting as if you disable it and set it to software then the stuttering becomes even worse.
                            Yet on my MINIX NEO-8 PLUS disabling hardware acceleration and switching to software actually reduces judder.
                              Dear Kaufuman,
                              Thank your valuable information. About the judders, is it obvious or slight? Would you like to upload your video ?
                              best regard.
                                Dear all,
                                Thank boys' discover!
                                About the root and netflix bug, there is a update and it will be pushed to you device with OTA.
                                If you version is older than 106k4, please update to 106 or 201, the next update will complete with OTA after clicking the "setting""update""online update".
