X2 H3 BOX images customized for Freaktab.
    I can t update my box to the last update.
    The update files are located in the:
    Local memory
    Directory "adupsfota"
    Someone can post lhe all directory "adupsfota"? And who cant online update can local update.
    Beelink X2 and Nexsmart D32 for now!!!
      It seems some people are still getting updates and some are just seeing nothing.
      I cant tell from the posts of the people that got updates if they have had their devices switched on every day and got the updates many days after the first reports, or whether their devices have been switched off and they got the updates as soon as they switched on - hope that makes sense....
      I dont know if this site has some sort of 'trickle' delivery of patches/updates so that they are released gradually.
      Anyway - if someone who has got the latest update could look in that adupsfota folder and post the contents that would be great.
      Easiest way if probably to install AIRDROID (from google play store). and then go to a PC
      X2 must be on wifi (not ethernet).
      Start Airdroid on the x2.
      It will show you a web address (like http://192.168.1.99:8888 )
      Type that into the browser on your PC and it will connect to the x2 - you have to ok the connection on the x2.
      Now you can browse the folders on your PC and download any files you like.
      The updates should be in the Files/SD card/adupsfota folder.
      If someone could post the update file(s) taht would be great for people like me to have a play with.
        "adupsfota" folder is empty,in my box. Why ?
          What version do you have? Just see in lhe settings.
          And what browser are you using?
            TRIGTOP please post the last firmware update 205k4 or someone else that received this update...
            Enviado do meu LG-D390n através de Tapatalk
              I have 204k4 and i use Es file explorer .
                Ok and you don t found the file update.zip nowhere?
                  i think that i saw a file with that name,but not inside the "adupsfota" folder. Is this the firmware file ? If yes,i 'll upload it here,tomorrow.
                    Yes this is the file. Can you see what size he have?
                    And yes please upload
                      I'm sorry ..there is nowhere the update.zip file ! I search everything,all files,but nothing ! Maybe,is there with another name ?
                        I dont know if there have another name.
                        Can you doing something...
                        with es explorer file
                        go to root memory where is installed the system
                        you found a folder called system
                        in the system folder you have a file called Build.prop
                        open like a TXT (Text) and rool at the bottom and you see the information about de OTA and the Stock Rom
                        choose edit in the top of the app and copy and the paste that information
                        this information maybe help to undersatand why some people have the update and some people no.
                        or just make a copy of the file and update here. (its more simple)
                          ro.build.id=KOT49H
                          ro.build.display.id=4.4.2 KOT49H 20151229 test-keys
                          ro.build.version.incremental=20151229
                          ro.build.version.release=4.4.2
                          ro.build.date=Tue Dec 29 18:40:49 CST 2015
                          ro.build.description=4.4.2 KOT49H 20151229 test-keys
                          ro.build.fingerprint=Allwinner/dolphin_fvd_p1/dolphin-fvd-p1:4.4.2/KOT49H/20151229:eng/test-keys
                          ro.product.firmware=Homlet4.4.2-Qin2-v1.0release
                          # begin fota properties
                          ro.fota.platform=AW_A30_KK
                          ro.fota.type=box
                          ro.fota.oem=trigtopH3_KK
                          ro.fota.device=XII
                          ro.fota.version=4.4.2 KOT49H 20151229 test-keys
                          # end fota properties
                            I saw in this file,that there are some dragonbox apps.
                            I was delete these 3 system apps. Is this the problem that i can't upgrade to 205k4 firmware ? I get the message that the system was damaged ! Any help ?
                              panlarp
                              To the people can't update from version 203K4 to 204K4 (like me) or from version 204K4 to 205K4
                              i think the only way is waiting the firmware upload here in the forum by TRIGTOP .
                              And while open ticket in gearbest or in the store the people buy the Beelink X2 Box.
                                AZW and TRIGTOP
                                Could you kindly post the Link for the 204k4 or 205K4 firmware for Beelink X2?
                                From My Beelink X2
                                Build Number
                                4.4.2 KOT49H 20151105 test-keys
                                Vendor Software Version
                                203K4
                                Lastest Update (Can't update by Firmware Over The Air)
                                Build Number
                                204K4
                                and
                                Build Number
                                4.4.2 KOT49H 20160107 test-keys
                                205K4
