X2 H3 BOX images customized for Freaktab.
    Here you go - http://www.mediafire.com/download/go...t/Kodi-lib.rar
    Put the libvrender.so in "/system/lib" and restart then install the apk, to fix the aspect ratio problem, disable the "AW codec" and put movie working, go to the aspect ratio and change to the one of your choice(mine was always 16.9) and change interlacing/deinterlacing from auto to enable, and save as default, after then enable again "AW codec".
      Thank you @superceleron
      I tested and works very well.
      Enviado do meu LG-D390n através de Tapatalk
      Beelink X2 and Nexsmart D32 for now!!!
        TRIGTOP, You can give the OTA version 203k4? On the cord USB PC does not see the TV Box. Installed version 202k4.
          TRIGTOP
          in attacmhent i upload the apk and logcat (please unzip the files) for the Tv app from my ISP Provider. The stream start but when try to up the bitrate the image freeze and i just can hear the sound. I hope you can fix this problem and this box will be perfect.
          thank you again for your support
            This box will probably never be perfect. Even without the KODI issues trying to play things via DNLA and MX Player from my PC results in an extremely glitchy experience. This box seems to hang and crash fairly regularly in general and is a poor product imo compared to my MINIX but obviously that is a more expensive box.
              Very hard to get a perfect box. I have gone through so many boxes myself. Some expensive ones like minix, and mygica. Some cheap ones. And they all have their share of troubles. This box is a good introductory to kodi, etc. I have bought many to give away to friends and family to introduce them to the world of Kodi and Android. If they find they like Kodi and the features it offer, they can decide to go for a better box. Hopefully, they enjoy the box with no issues and will remember the beelink or the zidoo brand (and allwinner cpu as I specifically tell them the make of CPU) when shopping for an upgrade. If they have lots of issues, they will want to buy something else (and another CPU).
                Will this image work on the CX-X3 box ?
                This is the picture of the box specifically.
                China-1 Stock | Buy CX-X3 4K TV Box Android 4.4 Vidon XBMC Remix OS Upgrade Quad-Core 4K H.265 Decoding Bluetooth 4.0 HDMI DLNA Miracast online at unbeatable prices. ✓Free Shipping ✓Limited Time Sale ✓Local Warehouses.
                  http://m.geekbuying.com/item/CX-X3-4...st-353176.html
                  it Works on cx-x3 but remote dosn´t and the led is red instead of blue
                    here you have, just flash it with the update app
                    http://www.mediafire.com/download/u9...pdate_twrp.zip
                    Thanks superceleron , which is that update app to flash TWRP? Phoenix?
                      Use update app that comes with the stock rom!
                        Thanks superceleron . I can't get it... I open "System Update" -> Local Update -> Select file. But it shows "Activity not found" message. What I'm doing wrong? I have the recovery image in the internal storage and in the microSD card. Thanks in advance!
                        EDIT: sorry: I rebooted into recovery with the microSD (recovery.img inside) and TWRP loaded!!
                          Nice you got it working
                            I waste more than 5 days trying to get PhoenixSuit recognizing my device .
                            I use Windows 10. PhoenixSuit won't recognize the device, despite it's correctly installed in Device Manager, It appears as a cryptic USB Device(VID_1f3a_PID_efe8).
                            That's ok... then the trick is to load image file in PhoenxiSuit and do a brute-force installation
                            This is to play with power button several times, and then put a clip in the little hole until appears the "mandatory ...." warning
                            At this point the user can choose a format option or an upgrade option.
                            I prefer upgrade in order to not reinstall all the stuff from scratch.
                            It will remove recovery program if some of this are used.
                            So the only thing I needed to do is to reinstall TWRP (my favorite) using a flash tool which is
                            Rashr - Flash Tool.
                            Nor even I needed to reinstall KODI 15.2 which I have running in my device.
                            Allwinner developers are not good in upgrade by cable. I recall suffering the same in an old tablet Ainol Novo 7 Aurora couple of years ago.
                            "Rock more than music it's a way of living"
                            Tablet RK2918 - Yifang M900HC 8" JB 4.2.2 Oma
                            Tablet RK3026 - Yifang M7100KLD 7" JB 4.2.2
                            Tablet RK3066 - Yifang M7000 7" JB 4.2.2
                            Tablet AML8726-MXS - Yifang M7000NBD 7" - JB 4.1.1
                            Phablet Samsung Note 3 - KK 4.4.2
                            Cell Phone Samsung GT-S5760M
                            - JB 4.0.3
                              I don't get it... so many people complaining about Kodi 14.2... why don't you all just update Kodi with 15.2? I just did an uninstall on my old kodi, and installed 15.2. No issues at all.
                              I did get hit by the bad image that TRIGTOP had sent out and it bricked two of my boxes. I was able to recover both of those tonight with a Type A male to male USB cord I found in a dollar store today. LOL! It was a bit tricky getting the Phoenix Suit to work, but I figured the trick out and res-erected both. Now they both have 202K4 and are humming along fine. Guess I can close my ticket with Gearbest!
                                Please share the trick. Phoenix suite does not detect boc. Phoenix suite will not flash my box even with Power button trick. Windows gives device a generic name. Phoenix card freezes and rom does not flash.
                                Sent from my GT-I9190 using Tapatalk
