X2 H3 BOX images customized for Freaktab.
    Hi any news on 15.2 kodi @trigtop
    Sent from my GT-I9190 using Tapatalk
      TrigTop, thanks for the updates!
      I just received my X2 today, and updated to the latest version. (System Update updated to 201K, then 202K appeared immediately after finishing the update process.)
      I have the same issue as Kaufman, since I use a SPDIF passthrough for my 5.1 surround system.
      With passthrough off, video playback is smooth, and I get 2.0 sound. With passthrough on, the 5.1 digital light lights up on the surround system, but the video stutters a bit.
      It is a fairly predictable stutter, where it plays smoothly for about 2 seconds, then freezes for a few frames, then plays smoothly again for 2 seconds before freezing again briefly, etc.
      I also notice that the pitch of the sound is lower on the passthrough audio than the downmixed (the voices sound deeper, the music a semitone or two lower), though the audio stays in sync for either mode. I think the downmixed pitch is the correct one, so that's quite odd that the passthrough audio pitch is lowered. I suppose this may be connected to the video stuttering.
      Thanks for all your efforts!
        Dear All,
        upload a new image for some special board.
        Sorry , for my mistake, there is a batch board (1080 pieces ,produced at 20150910) built in a risk that power on fail and just light RED LED. I will describe this mistake here with detail.
        Thanks.
          Trigtop:
          Is the H3 chip compatible with all the new requirements for Kodi 16?
          With the new developments for kodi at a lightning fast pace, we want to make sure that our box is going to be obsolete and cannot play newer versions of kodi.
            The new firmware for the red light issue fixed my problem but the 1080p ui is gone
            youtube resolution is capped at 720p without the 1080p ui
              203k4 released.
              OTA acts.
                Originally posted by piggy99 View Post
                Trigtop:
                Hi Piggy99,
                Allwiner will keep pace with new kodi, they have a specialized kodi team.
                Now H64,next generation of H3, with 64bit android will build kodi 15.x
                  That is about time, you need to port the kodi 14.2 fixes to kodi 15.2...
                  Did have a look on the logcat o posted on the other thread?
                  Btw enable xbox360 driver on the kernel... and use my kcm and kl files...
                  Its nice to see a factory giving support to their product for a change...
                  Keep the good work
                  Dear Superceleron,
                  It is difficult for me to download your ROM. Would you like to send just kcm and kl files to me ?I want to built it in my ROM. Thanks
                    Originally posted by TRIGTOP View Post
                    Hi Zebrain
                    Doing it. I will respond the results.
                    thanks.
                    Hi TRIGTOP
                    Thank you fou your support.
                    Can you tell me if you managed to see the problem with TV App from my ISP Provider? The logcat from superceleron post should help:
                    Dear Superceleron,
                    ​I know superceleron will help with this.
                    And i just want to make a suggestion TRIGTOP, the Custom Kodi 14.2 CedarX Hw acceleration made by superceleron works very smoth and very fast. Can you put this option with your Kodi? And if you can put support for Xbox 360.
                    Thank You TRIGTOP
                    Thank You superceleron
                    Beelink X2 and Nexsmart D32 for now!!!
                      Here you have it TRIGTOP check the attachment!
                      Sorry Zebraino I do not not have the device!
                      So no more debugging from me!
                      Sorry...
                        superceleron
                        You can not even further develop this Box . But your contribution has been enormous. And that may assist the Trigtop to provide these changes and this files is very valuable . Thank You
                          Hi Piggy99,
                          Hi asking about 15.2 Kodi for X2 H3 not new box?
                            Sorry...
                            Please provide apk download link of your modified Kodi. Thanks
                              Wont work you need a file from my rom!
                              But i can upload the 2 the apk and a file for you guys put in "/system/lib"
                                Thanks will be awesome and might help them add to official rom too..
