X2 H3 BOX images customized for Freaktab.
    This please do not work on cx-x3 box...
    I can flash it with no problems but on the new fw do not work welll (nothing from the remote and the wifi)
    Is there something to do please.
      Thanks to @gearbest
      This is the links to download the firmware 204k4:
      root system: link: http://pan.baidu.com/s/1pKbYAiZ password: 4ecs
      t-card update: link: http://pan.baidu.com/s/1dEq6a8x password: ob5c
      root tools: link: http://pan.baidu.com/s/1pJZWHwJ password: h76v
      Source message:
      http://freaktab.com/forum/advertiser...647#post550647
      Beelink X2 and Nexsmart D32 for now!!!
        Thanks very much for the links.
        Sadly it appears you have to create a baidu account in order to download and that looks to require a chinese mobile phone number and being able to sign up in chinese.
        While I can use google translate on most of the screens its not good enough to let me sign up.
        If anyone is able to download these files and upload them somewhere else it would be hugely appreciated.
          Hope Helps robjg63
          Firmware 204K4
          Build Number
          4.4.2 KOT49H 20151229 test-keys
          Vendor Software Version
          204K4
          Features:
          1. Update Media Libraries;
          2. Fix the Issue that some device's "spdif not active after system reboot;
          3. Add 360XBOX support
          https://mega.nz/#!O49lmazb!Q4yB7mxrz...u9XQ6cwvMYtKxw
          OTA
          http://mega.nz/#!X8VkERAC!oabuDkls-e...IRh8BXd5rq07Ug
          PhoenixPacketV400
          http://mega.nz/#!38kxBLrb!p_wrn72xyO...UiWquehbamFc_I
            What's new on this 204k4 firmware?
              Features Add in my post
                Just a stupid question. Can the 204k4 be updated using the zip via the local update? I want to sent it to my friends who are unable to update. I don't want it to be something they cannot do or create problems for ie ie have to show up to fix their problems. LOL.
                Those guys are not going to like the phoenix suite updates as they have failed doing many times.
                  I've tried the firmware 204K4 posted today.
                  (Thank you Zebraino for mega mirror)
                  With:
                  - Preinstalled KODI: Passthrough causes stutters in video playing.
                  - Latest KODI Nightly: Passthrough causes a lot of audio noises and H265 videos aren't decoded.
                  Is there someone who is able to use passthrough without problems?
                    What method you upgrade your box with? local with the zip? Pheonix suite with the img?
                      Using the img.
                      Did passthrough works without problems for you? Which firmware? Which KODI version?
                      BTW i had the same problems even with older versions of the firmware.
                        Thanks Zebraino Will download the file today and install it.
                        I will be curious to see if it updates from 204k4 to 205k4 that has been mentioned.
                        piggy99 - it will be the USB cable and Phoenix suite for the .img file.
                        The OTA file is the one you can install locally on your box.
                          I am going to try it tonight and if it works let some of my friends know
                            Installs great and takes you back to the 'standard' software stream (if like me you installed some other releases and couldnt find the images to get back to standard).
                            Immediately after installing it takes you the update for 205k4 (7 January 2016) - so I now have the most up to date release - will need to see how this goes now.
                            Thanks to all.
                              if you have problems with Kodi,try the SPMC
                                Nice Work!!! :-)
                                Thank You!!!
                                Please can You tell me how I can change the monitor solution to a 4:3 PC-Monitor?
