1. Download the root tool from http://www.putlocker.com/file/A755C9FA1CD8420E and extract it somewhere. This is my fixed version of the original Vondroid batch file which will install SuperSU correctly. You will see the file TPSparkyRoot.bat inside the RK3188_ROOT folder. You will need to run this later on step 4.
2. Turn USB debugging ON in Settings -> Developer Options of the tablet
3. Connect the USB cable to the USB port on the M9 and the other end to the PC
4. Run the TPSparkyRoot.bat and follow the instructions. The tablet will reboot several times during the process.
