Wish list for PiPo ROM's
wish list for U1 Pro
will it be too much if you include gameloft game fix? also if you can include these mod
http://forum.xda-developers.com/show....php?t=2113150 crossbreeder mod from xda
. that's all aside from the mentioned list in first page.
Circle Battery Alternative
Some of you have requested that I tweak the UI to include a Circle Battery icon.
I was looking into this and found a solution that is much easier and you have more control of the look you are getting. You need to have the Xposed Installer installed on you system you can get it here:
General information on Xposed has been moved to this thread: http://xdaforums.com/xposed/xposed-installer-versions-changelog-t2714053 The FAQ has been moved to this thread: http://xdaforums.com/xposed/-t2735540 Questions, suggestions, bug reports...
Then go to UOT Kitchen and design you battery circle:
Ultimate online theme kitchen for Android phones, UOT Kitchen, Customize your phone online, Custom and stock roms
Just follow the instructions on their site. There is an option to create an apk that you install from Xposed.
Just wait a few minutes for them to create you apk and download it.
The Xposed version is ONLY for the battery icon MOD, nothing else in the kitchen is compatible with Xposed.
Enjoy!Randy
Dont know if it has been asked already.I have a Pipo M6 with 3G, and I use it with one of the local providers here. But instead of displaying the humanly more understandable name of the provider, it displays the code of the provider, 20408 in my case. Is there a way to get the name and not the code displayed?Another thing I would like to add is the possibility to be able to sen/receive sms on the 3G Pipo M6. This is possible on the Nexus 7 3G with some added apk's, so I think it should be possible on Pipo too? If the messaging apk is included, the one used to sms (the standard android messaging apk) it should work on Nexus, so hopefully on Pipo 3G as well??
Originally posted by BamaPanda View PostI have the RR1.7 loaded ...great ROM.
How about a mute icon either in at the taskbar or in the drop down assess at the upper right?
The noisy keys in the taskbar are ..well, annoying!
Support your local flasher
Current devices : Pipo MAX M8 Pro - Samsung Galaxy S4 - Intel NUC
Originally posted by pr0xZen View PostNoisy keys? Why don't yoaccessible able touch sounds? Settings > Sound > uncheck Touch sounds.
Still ...woundn't a single mute icon, easily accessable and without backing out of a window be nice?Cube T9; Pipo M8 Pro (on life support); LG gPad
Re: Wish list for PiPo ROM's
Just turn the volume down low with the already existing volume keys, it will automatically mute.
What we DO need on the soft key bar, is Menu button. That way we can remap the volumerocker keys to actual volume and still have a functioning menu key.
This can be done with SotKeyZ - although that would mean loosing screenshot and volume control - and I still feel it would be a nice addition to the "stock" navigation bar.Last edited by pr0xZen; 18 July 2013, 14:38.Support your local flasher
The parameter file has to be written to increase the app space. My custom ROMs come with 2gb default with more choices.
I'm downloading the firmware now.
Also for the M6. I have my day cut out for me......hahaha.
Oh, and I have 3 other ROMs cooking...including the new M7.
RandyRandy
Originally posted by rrileypm View PostThe parameter file has to be written to increase the app space. My custom ROMs come with 2gb default with more choices.
Randy
Thank you! The latest one for Pipo M8 Max is M8software_englishversion_20130412
What tool to use to write the parameter file to increase app space? What tools are you using to make custom rom sir?
For Pipo M5
And lastly, I have Pipo m5 as well, does the riley rom you made for that is bug free? Thanks! Does the 3g/sim slot works?
You can edit the parameter file in notepad, but it is extremely difficult to learn how to edit this correctly. I use many tools, but I could direct you a very long thread which contains the information you need...ROM building is quite a process.
The latest firmware for the M8 Max (3088) is what I based my RileyROM on...
Check this thread for the M5.....
To my knowledge, there has not been an issue reported for 3G. I do have the 3G version of the tablet, but the installed 3G modem isn't compatible with United States 3G carriers, so I'm unable to test it.Randy
Originally posted by rrileypm View PostYou can edit the parameter file in notepad, but it is extremely difficult to learn how to edit this correctly. I use many tools, but I could direct you a very long thread which contains the information you need...ROM building is quite a process.
To my knowledge, there has not been an issue reported for 3G. I do have the 3G version of the tablet, but the installed 3G modem isn't compatible with United States 3G carriers, so I'm unable to test it.I followed a video from youtube.
Anyway, as for M5, I thought Pipo M5 only has the 3G version?
Thanks for your rom! Keep it up man!
There are currently 4109 users online. 2 members and 4107 guests.
