is this the same link you saw randy?
Wish list for PiPo ROM's
I didn't see that one.
I'm downloading it...it may be a few days.Randy
Re: Wish list for PiPo ROM's
Originally posted by testertester View PostI WISH you could add a MULTI USER function for my pipo m9 pro...
Sent from my M7pro using Tapatalk 2Randy
Larger "parameter files" incorporated in your ROM updates
GREAT JOB on your ROMs!
I have a M6 Pro (16GB NAND) and a M9 Pro (32 GB NAND).
I've been installing several game APPS that are over 1GB each. I am running out of "space" in the User install area. I would not prefer installing APPS on the external SD card for speed reasons. I realize this is more work for you, but I would like to see 12, 16, 24GB parameter files bundled with your future (or current) ROM updates.
THANKS
Sam
PiPo M6 Max/Pro
PiPo M9 Pro
Sure, I can go that high...it depends on how much room you want left on the internal sd for the data all those games generate.
I was doing 12gb parameters for a while. It's just a lot of work making them.
My question is...do we need sooo many choices? What are the most popular sizes?
Instead of 2,4,6,8gb...doing 4,6, and 12gb? Would that be better?
RandyRandy
Higher parameters
Originally posted by rrileypm View PostSure, I can go that high...it depends on how much room you want left on the internal sd for the data all those games generate.
Randy
I used the 12GB when I saw them. With external SD capability, leaving a "larger" storage area isn't that critical with the PIPOs. I understand the "pain" involved in creating these files. I would forgo the "lower choices" and use higher iterations such as: 4, 8, 12, 16, 20, 24
These numbers should strike a balance for 16/32GB NAND owners. I hope this wins your/community support.
Hopefully, PIPO is working on fitting in 64/128GB NAND for their next series.
Sam
PiPo M6 Max/Pro
PiPo M9 Pro
Now that I have my system figured out...it isn't really a pain. I enjoy making these tablets fulfill better functionality.
My hobby is making ROMs...not playing games...so it is really up to the users to decide what you need. As long as people understand the limitations...I don't really care what parameter sizes to make.
That being said...is it very efficient to make parameter sizes that people don't even use? I'm more inclined to pick a few popular sizes that make sense.
I always flash the 2gb default just because I don't install that many apps. But 4 would be OK with me.
So how about 4 as default. Then 8 and 12.
Would that be OK?
Anyone else have opinion?Randy
Higher parameters
Originally posted by rrileypm View PostNow that I have my system figured out...it isn't really a pain. I enjoy making these tablets fulfill better functionality.
Would that be OK?
Great! How about a 16 and 24 also for the M9 Pro or any 32GB tablet.
Sam
Sam
PiPo M6 Max/Pro
PiPo M9 Pro
No problem.Randy
Is there any possibility to see multi-window support for pipo m6 - m6pro?if you appreciate my efforts this is the link for any donation:
I'd like all system apps on a ROM to be updated with latest versions, saves me updating then integrating updates (some refuse to update says out of space)
Integrating updates seem to cause "not responding" lock ups, even after rebooting. So having latest version in a build would be handy, as no messing around at system level
From memory
Chrome
Maps
Calender
Gmail
Play Store
Play Services
Talk
Framework
Voice Search
Play Books
Google Search
Sound Search
Which ROM are you using? I haven't heard of those update problems.
RandyRandy
There are currently 2212 users online. 0 members and 2212 guests.
