This OE using Kodi 16.1.
LibreELEC & OpenELEC for Tronsmart Vega S95
It might be good idea to do a kodi Thread with links to working versions for each device so that its in one place seems to be a huge list of working off sets from kodi example zdmc spmc and HPH specific devicesMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
I am having some issues installing the autoscript and the telos_update_uboot.zip file. I am currently running Finless rom 1.0 do i need to revert back to stock?I am getting message footer and signature failed in recovery when trying to update. Any advice appreciated.
I have kept the telos_update_uboot as a zip file
The exact message is failed to mount /dev/block/mblk0p1 on / sdacrd by read only (invalid argument)
Just about to try another sd card.Last edited by desmondo; 06 April 2016, 17:49.
Originally posted by desmondo View Posti need to revert back to stock?I am getting message footer and signature failed in recovery when trying to update. Any advice appreciated.
The message about /dev/block/mblk0p1 often the case with problematic cards. I tried a lot of cards work best old class 4 card (2 Gb). Not working Kingston class 10. On PC everything is well recorded and read, S95, doesn't work, can't read data.
On k3 s905 may work, need to see the output from the command printenv u-boot, what would definitely say.
Thanks Balbes150 , can command be run from terminal within android or do I need to connect internal hardware to board. ?
e123enitan Please write more, what system You tried and the result. I'm glad You have everything working.
You can use any method available to You.
Cheers!
Just to add, have U considered
opening a thread in Kodi forum for wider exposure where large audience can review and then post a feedback, just my 2cents thoughtsLast edited by e123enitan; 08 April 2016, 22:45.
ps/
I thought, perhaps you can use this safe method to start Openelec, Debian etc on any device. If I see the output of the printenv command, then i can create a script for other devices (Amlogic S805 S802 etc)
There are currently 2339 users online. 0 members and 2339 guests.
