LibreELEC & OpenELEC for Tronsmart Vega S95
balbes150, I use the img for 17.4 Final, the process installed nicely on my SDCard, the process takes few mins to complete the image write.
I simple checked few settings and using Tronsmart remote and USB remote to navigate through Kodi, it seems fine to far.
When I write the image from SDCard to EMMC, the process seems to start nicely but GET STUCK for 15 mins at "Writing device tree image", then my TV screen when blanked.
Then I decided to power off/on Vegas 95, it seems to have writen 17.4 Final, BUT Tronsmart Remote will not work.
I suspected the image wasn't completed, I NEVER DID NOT HAVE this sort of issue since I have been using your build.
Please can check why this my be the case.
My box Vega 95 METAL
Originally posted by e123enitan View Postbalbes150, I use the img for 17.4 Final, the process installed nicely on my SDCard, the process takes few mins to complete the image write.
Any idea how to fixed the Remote Issue it is not working
Originally posted by balbes150 View Post
Have you tried to add the file remote.conf file (necessary file is in the image, it is necessary only to rename the remote.conf) ?
Originally posted by balbes150 View PostAfter recording of the image in the root there are files for several models. Rename "remote.conf.vega" in the "remote.conf". Either use a standard procedure to record a desired file in the directory /storage/.config.
The remote works with USB, when I rebuild to Internal EMMc, the remote will not work, it can only power on/off, but it won't function to navigate within Kodi. I'm not sure sure what to do, if it work in USB, and the same is used to write ti internal something is not working fine. Can I rebuild the box back to Android, and how if possible?
Where is the flashing, and steps to write Android, could you send a link to the flashing.Last edited by e123enitan; 13 September 2017, 16:39.
There are currently 2198 users online. 1 members and 2197 guests.
