LibreELEC & OpenELEC for Tronsmart Vega S95
    @babels, Let me first apology for many issues that I have raised and thanks as always for your support and quick response.
    Every time I launch a PVR, I will noticed that it takes time to load, also when I changed channel it get sluggished, so I pulled a debug log, I noticed series of errors, could you help figure out why the FFMPEG is creating a issue.
    A full debug log is here
    22:33:21.262 T:545143013600 DEBUG: CAMLCodec:ecode: ret: 2, sz: 0, dts_in: 18442240474082.1797[0], pts_in: 18442240474082.1797[0], adj:0, ptsOut:-102481912659968.0000, amlpts:0, idx:2720, timesize:0.0000, drain: 1 22:33:21.272 T:545143013600 DEBUG: Previous line repeats 1 times. 22:33:21.272 T:545143013600 DEBUG: CVideoPlayerVideo::OpenStream - open stream with codec id: 28 22:33:21.272 T:545143013600 DEBUG: CAMLCodec::CloseDecoder 22:33:21.276 T:545402122464 ERROR: ffmpeg[7EFC7FF0E0]: [NULL] SPS unavailable in decode_picture_timing 22:33:21.276 T:545402122464 ERROR: ffmpeg[7EFC7FF0E0]: [NULL] non-existing PPS 0 referenced 22:33:21.313 T:545402122464 ERROR: ffmpeg[7EFC7FF0E0]: [NULL] SPS unavailable in decode_picture_timing 22:33:21.313 T:545402122464 ERROR: ffmpeg[7EFC7FF0E0]: [NULL] non-existing PPS 0 referenced 22:33:21.314 T:545402122464 ERROR: ffmpeg[7EFC7FF0E0]: [NULL] SPS unavailable in decode_picture_timing 22:33:21.314 T:545402122464 ERROR: ffmpeg[7EFC7FF0E0]: [NULL] non-existing PPS 0 referenced 22:33:21.339 T:545402122464 ERROR: ffmpeg[7EFC7FF0E0]: [NULL] SPS unavailable in decode_picture_timing 22:33:21.339 T:545402122464 ERROR: ffmpeg[7EFC7FF0E0]: [NULL] non-existing PPS 0 referenced 22:33:21.364 T:545402122464 ERROR: ffmpeg[7EFC7FF0E0]: [NULL] SPS unavailable in decode_picture_timing 22:33:21.364 T:545402122464 ERROR: ffmpeg[7EFC7FF0E0]: [NULL] non-existing PPS 0 referenced 22:33:21.364 T:545402122464 ERROR: ffmpeg[7EFC7FF0E0]: [NULL] SPS unavailable in decode_picture_timing 22:33:21.365 T:545402122464 ERROR: ffmpeg[7EFC7FF0E0]: [NULL] non-existing PPS 0 referenced 22:33:21.365 T:545402122464 ERROR: ffmpeg[7EFC7FF0E0]: [NULL] SPS unavailable in decode_picture_timing 22:33:21.365 T:545402122464 ERROR: ffmpeg[7EFC7FF0E0]: [NULL] non-existing PPS 0 referenced 22:33:21.402 T:545402122464 ERROR: ffmpeg[7EFC7FF0E0]: [NULL] SPS unavailable in decode_picture_timing 22:33:21.402 T:545402122464 ERROR: ffmpeg[7EFC7FF0E0]: [NULL] non-existing PPS 0 referenced 22:33:21.402 T:545402122464 ERROR: ffmpeg[7EFC7FF0E0]: [NULL] SPS unavailable in decode_picture_timing 22:33:21.402 T:545402122464 ERROR: ffmpeg[7EFC7FF0E0]: [NULL] non-existing PPS 0 referenced 22:33:21.440 T:545402122464 ERROR: ffmpeg[7EFC7FF0E0]: [NULL] SPS unavailable in decode_picture_timing 22:33:21.440 T:545402122464 ERROR: ffmpeg[7EFC7FF0E0]: [NULL] non-existing PPS 0 referenced
      I did a further research, what's unusual is the time difference between opening the stream and the videoplayer start, I think something is not right with the FFMPEG syncro between vidoe and audio
      Quote:22:33:21.189 T:545402122464 DEBUG: AddOnLog: DVBViewer Client: StreamReader: Started; url=http://192.168.1.104:7522/upnp/channelstream/3839.ts
      22:33:21.251 T:545402122464 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
      22:33:21.567 T:545402122464 DEBUG: CVideoPlayer::HandleMessages - player started 1 (aka VideoPlayer_AUDIO)
      22:33:28.839 T:545402122464 DEBUG: CVideoPlayer::HandleMessages - player started 2 (aka VideoPlayer_VIDEO)
        Hi Babels, did you get a chance to look into this issue, it only happen with HD channel, I dont see error when changed to SD channel,
        Although I reported the issue on Kodi >PVR>DVBViewer addon, the issue seem related to either software or Hardware of Libreelec. To be sure I run the PVR DVBViewer on Kodi windows 7, I don't see the issue.
        let me know if you see need further info.
          Could you prevent Tronsmart Log appearing when the system boot, so it only show Libreelec log only, personally I dont like too many log appearing when the system boot.
          Display Tronsmart Logo to be in u-boot. It is not related to the Assembly LE. To disable the Logo Tronsmart need to change the firmware itself.
          I don't know why you have FFMPEG throws the error (I'm not specializers to work with video and audio).
            [QUOTE=balbes150;n678722]
            That is fine, I thought it's something you can change or modified
            I will post the errors message in Kodi or libreelec for help.
              Hi Balbes, could you implement this approach in your build to update your build.
                  Hi Balbes, Do you have update for the release 17.5.
                    https://forum.libreelec.tv/thread/75...or-s905-s905x/
                    I'm need to have a network resource on the Internet (to host images), I there is no such resource.
                    To all
                    Update image LE 20171102 (for S905 S905X S912)
                      No worries, it is just a thought
                      To all
                      Update image LE 20171102 (for S905 S905X Sjust a 912)
                      Thanks, for your continuous supports, this version work perfectly for me for now, no issue discovered YET.
                      Cheers!
                        image 17.6_20171120
                          image 17.6_20171120
                          Great work!
                          Cheers!
                            image 17.6_20171120
                            Thanks ! Works well
                              Thank you!!!!
                                update image 20171221
