LibreELEC & OpenELEC for Tronsmart Vega S95
    Image update, version 20170915.
    In this version added a script s905_autoscript_data_to_emmc. This script is intended for running the system from external media (SD card or USB flash drive) with the location of the user's data and settings LE in the internal memory eMMC. The details of why this is necessary, you can read in this thread.
    Pay attention to not run steps from this topic to do. Simply replace the script s905_autoscript on an external drive, the new version. Script works with all carriers - SD card and USB flash drive.
    To use this option, you need to rename the script s905_autoscript_data_to_emmc in s905_autoscript. I recommend before replacing the script, save the primary file s905_autoscript to return to the previous use case, where data and settings are stored on an external drive from which you are running the system.
      https://forum.libreelec.tv/thread/94...mory-for-data/
      Hi Balbes !
      Can I just upgade from LibreELEC-S905.aarch64-17.3_20170801 version to LibreELEC-S905.aarch64-17.4_20170915 with the tar file in update folder or do I have to use an SD Card inevitably ? (I only have LibreELEC installed in the internal memory)
        Originally posted by ZZM View Post
        Hi Balbes !
        You can try from the beginning to save your current settings , and then perform the upgrade. If something doesn't work, you can perform a clean install and bring back your settings.
          Thanks for your answer, it worked.
            v20170925
              v20170925
              Hi what is new in this version.
                Hi Balbes, wondering if you could assist, I am seeing a lot of errors in the latest build, I'm not certain what my have cause the errors, either it's Libreelec or Skin or what, please find the attached log for your review, let me know what you think.
                Log Angel (1).txt
                  I do not see anything critical in the log.
                    @ Balbes150, I notice in the latest build 90/25, when I write the image into the internal drive, it will stopped and did not go passed "writting device tree image" after several mins while it seem it hang, the TV screen goes black. When I removed the ac cord to power the device. "Remote control will not work for three units"
                    wrttingsystem patiotion...done
                    writtingsystem files...done
                    wrtting device tree image..... at this stage it stopped writting after few minus the TV screen goes black until I turn the power off
                    Here are list of files in the SD drive, is there some changes I have to make to any of this file to get the remote to work
                    aml_autoscript
                    aml_autoscript-Winzip
                    dbt
                    dtb.img.backup
                    install,sh
                    kernel
                    kernel.img.md5
                    recovery.img.md5
                    remote.conf
                    remote.confi7pro
                    remote.cong.vegas95
                    remote.conf.vim
                    s905_autoscript
                    system
                    system.md5
                      update v 20171010
                        aml_autoscript
                        dbt
                        dtb.img.backup
                        install,sh
                        kernel
                        kernel.img.md5
                        recovery.img.md5
                        remote.conf
                        remote.confi7pro
                        remote.cong.vegas95
                        remote.conf.vim
                        s905_autoscript
                        system
                        system.md5
                        1. Check your media for availability.
                        2. Rename the file remote.conf.vegas95 to remote.conf and start the installation again.
                          Thanks, I shall give it try tonight and post my findings.
                            Works fine, Thanks
                            I have a request for my self, not sure if the community mitgh like the idea and if its possible, could you make a s905 build with out Tronsmart splash, so the system boot only to Libreelec splash, therefore, on going forward onecan just update with Tar file.
                            Let me know your thoughts if it possible, personally I have too many splash
                              Works fine, Thanks
                              Sorry, I don't understand the question.
                                Could you prevent Tronsmart Log appearing when the system boot, so it only show Libreelec log only, personally I dont like too many log appearing when the system boot.
