Updating image with a Krypton-17 (20170210).
LibreELEC & OpenELEC for Tronsmart Vega S95
Originally posted by balbes150 View Post
Thank you for the detected error in the image name. I have corrected the error. For those who have already downloaded this way, for the record, after unpacking you need to add the extension ".img".
https://yadi.sk/d/ysAgoIWT32M9Hn
Hi I just installed this version, it looks fine, but It is missing all the PVR addons, I get error message when I launch Libreelec add-on" could not connect to repository", how do I side load the PVR addons.
23:31:13.581 T:546668802272 ERROR: CCurlFile::Open failed with code 404 for http://kszaq.libreelec.tv/addons/8.1...ons.xml.gz.md5
23:31:13.581 T:546668802272 ERROR: Open - failed to open source <http://kszaq.libreelec.tv/addons/8.1/S905/aarch64/addons.xml.gz.md5> 23:31:13.581 T:546668802272 ERROR: CRepository: failed read 'http://kszaq.libreelec.tv/addons/8.1/S905/aarch64/addons.xml.gz.md5'
ThanksLast edited by e123enitan; 11 February 2017, 16:55.
Version update Krypton (20170216). Fixed installation errors in the internal memory. In the presence of the media at the root of the first partition (FAT), the file "remote.conf" it will be used to record to the internal memory. If you install to internal memory (eMMC) , when you run the LE from the internal memory will error (there is no /dev/system), you must rerun the installation.
Originally posted by balbes150 View PostVersion update Krypton (20170216). Fixed installation errors in the internal memory. In the presence of the media at the root of the first partition (FAT), the file "remote.conf" it will be used to record to the internal memory. If you install to internal memory (eMMC) , when you run the LE from the internal memory will error (there is no /dev/system), you must rerun the installation.
Updated the images LE 20170219.
For those who have LE already installed in internal memory (eMMC), re-installation is NOT required. The difference of the new images from the former only in the installation procedure in the internal memory. No longer requires manual renaming script "install.sh". It is sufficient to choose the desired menu item in the group "Off". The system, on reboot, perform installation and copy all the settings from the external media in the inside memory. Pay attention that the new system install on the internal memory automatically copies all existing at the time of installation settings in the internal memory. This means that when you select the menu item "Install to internal memory eMMC", all created on an external drive settings will automatically be copied to the internal memory. In the new system is not necessary after the installation to configure everything again.
Hi, Just want to report, that there are several errors in the latest build
There are currently 4823 users online. 3 members and 4820 guests.
