LibreELEC & OpenELEC for Tronsmart Vega S95
    I installed Libreelec on my Telos emmc memory and am very happy with it. It is stable and works like a charm.
    But I still have a question, as I'd like to try a Odroid-C2 based OS on a USB stick (live, no need to install on emmc yet). How can I do that, is the uboot still able to boot from usb ? I burnt the image with Etcher and now have one partition BOOT (FAT16) of 67MB and one named Linux of 1.6GB with no type ? diskutils says " File System: None".
    Well as you may understand it doesn't boot.
    Thanks for help
      Originally posted by balbes150 View Post
      The build process LE is not complicated. The main problem that you will need to decide the imposition of the new changes in the source code to the old code. All changes in the source code the entire Assembly LE are interrelated. For example, for the new (fixed) function in KODI you need to change the code of KODI, the kernel code, the code decoder ffmpg, library code, aml, etc. So if you want to start to collect your own version, you need to prepare to study all the code and build process LE.
      I would be happy if the number of collectors LE will be expanded. It will quickly update the code and make improvements from each collector.
      Thank you I will begin reading up and learning the process to compile. I would like to contribute when and if i can.
        Originally posted by Hiwyx View Post
        Thanks for help
        Up please !
        Here is some more informations :
        I ran the u-boot image again using the "FN" button, I guess something happened as the boot took a while after that. I did that because I read somewhere that after flashing an image, the multiboot is overwritten.
        The image I'd like to test is Jeedom, based on Debian Jessie. Can download here : https://www.amazon.fr/clouddrive/sha...QPGow3DFtIFaRw
        Also, I think the problem is about the boot of this image, but I really have no idea what to do there. I compared to the boot partition of libreelec, I hoped I could just replace some files but they're all different.
        Is there any post explaining how to adapt the boot of a ODROID C2 image to general S905 box ?
Name:	Screen Shot 2017-06-04 at 16.20.48.png
        Any help would be appreciated, I'm currently stuck
          update v 17.3_20170614
            v 17.3_20170622
              v 17.3_20170622
              Thanks, install it right now.
              Can you let the link when you post an update please ? (I have it in my favorite links, but it's for other people)
                v 17.3_20170622
                Thanks from me as always, yes I agreed pls add llink to the post it would ensure easy retrieval of the update plus helping new comers.
                Cheers!
                    Thank U
                      Hi, I'm using your openelec version for a long time. But, i want to upgrade to libreelec.
                      How can i upgrade to libreelec from openelec? Thanks.
                        hi balbes,
                        thanks for newer version.
                        But where can i get Information about Changelog?
                        you update often , any chance to know what change you have done?
                        Which kernel do you use in latest build?
                        Nougat or Marshmellow?
                          This is possible only through a new installation.
                            Originally posted by tunay View Post
                            hi balbes,
                            So this version is based on git Kszaq, so almost all changes are specified in the topic, can be attributed to this version.
