LibreELEC & OpenELEC for Tronsmart Vega S95
    See to git kernel
      Originally posted by balbes150 View Post
      i dont understand nothing. Github is for pros.
      is it nougat or MM kernel?
        As far as I know, this is MM.
          This is possible only through a new installation.
          Is there any step by step guide to do that? For example, revert back to android then install libreelec to internal memory? Thanks again.
            v 20170628
              Write the image to a external drive, rename the file to the desired file to the remote control in "remote.conf", run the system from external media, check all functions. If everything works the way you want, select the off menu item "Reboot to Install for eMMC" and when you reboot the system will automatically write the LE to the eMMC.
                v 20170704
                fix splash
                  v 20170704
                  fix splash
                  Hi, everything was good on v20170628, just updated to v20170704 and have a black screen with yellow / green / blue lines at boot, and libreelec splash screen never shows.
                  I stay on black screen with yellow / green / blue lines indefinitely.
                  Edit : updated back to v 20170628, boot perfectly.
                    v 20170704
                    fix splash
                      Originally posted by e123enitan View Post
                      Works for you ?
                        balbes150 just updated to the new image. Had some issues still with the splash screen as well as horrible juttering on video and audio out of sync. Going back to the previous image for the mean time. BTW keep up the awesome work!
                          So I went back to previous image and still the same problems. Seems like the CPU is maxing out playing a 1080p h.264 file. Was doing great up until the update.
                            v 20170704
                            fix splash
                            Hi Bud, I tried this version, but it won't load, at reboot it's blank, so I went back to prior version, keep us posted when the latest revision is available, thanks for your supports, good job as always.
                              Hi, Could you make it possible to exclude Tronsmart splash, just to have LE & Kodi splash's only.
                                This is a function of u-boot. It has nothing to do with LE.
                                To ALL
                                v 20170705
