LibreELEC & OpenELEC for Tronsmart Vega S95
Originally posted by Lucky3058 View Postbalbes150 did you figure out why the CPU is maxing out and getting high temps with the latest release?Last edited by e123enitan; 07 July 2017, 20:06.
balbes....Looks like whatever was wrong with that firmware from the other day may have fried my box with the constant high temps. I am not blaming anyone but myself since I didnt bother to check them right after the upgrade. It still boots up and runs Android alright but seems as if my Wi-Fi and LAN are dropping in and out constantly, so I am thinking that maybe that chipset overheated. I will be ordering a S912 box today, but wanted to see if you had any suggestions on how to revive my S95 Telos since I loved that box and your LE builds. I have already tried doing a new image write from your latest release and rebuild the Kodi DB but I am still seeing high CPU usage on 1080p playback and the WiFi/LAN issues. Thanks again for all you do for this community, I know I dont post much but still wanted to pass along my thanks!
Originally posted by balbes150 View Post
This is a function of u-boot. It has nothing to do with LE.
To ALL
v 20170705
The temperature, has dropped to 54c, I think the high Temp could have been because weather is very hot and also I was scanning larger Library from Server to Libreelec which takes about an hour.
Secondly, I have noticed that when the system boot or start, there's a long script that runs through, this was never there before (pls correct me if I am wrong)
Those are my observations, aside it's running fine for now if I spotted a issue I shall raised it.
Cheers!Last edited by e123enitan; 07 July 2017, 18:09.
To ALL
v 20170705
ThanksLast edited by e123enitan; 07 July 2017, 18:08.
Hi balbes150, I have had bad experiences with 6/28 and 7/5 builds in both instances, Live TV HD stream plays in slow motions, and several TV shows files plays in slow motions regardless of how tricked Kodi settings.
However, in the box that is in bed room with this build Kodi.17.1-RC2 Git:5814568, complied : March 23 2017, Version 8.0.2 (Kernel: Linux 3.14.29) works flawless.
Would you be Kind to post this build Kodi.17.1-RC2 Git:5814568, complied : March 23 2017, in your usual repository as would like to install this my other devices, MY CHILDREN ARE DRIVEN CRAZY.
Or
Kodi 17.3 Git 147cec4, compiled: May 31, 2017Kernel Linux 3.14.29, this also work fine
Thanks for your kind supports as alwaysLast edited by e123enitan; 13 July 2017, 13:40.
Hello, i tried to install from LibreELEC-S905.aarch64-17.3_20170801.img.gz file. Inside the file, there is no install.sh file. So, when i clicked "reboot install to emmc" it's doing nothing.
I tried install with LibreELEC-S905.aarch64-17.3_20170705.img.gz file. It has install.sh file, and successfull install to emmc.
Then, i downloaded LibreELEC-S905.aarch64-17.3_20170801.tar file to update current version. Put update file to "update" folder, then reboot for install. When the install finished, it stuck on the Tronsmart logo.
Is there any problem with new 01082017 release? or i'm doing something wrong? I'll re-install 05072017 version, and will stay this version.
Originally posted by Rooler View PostHello, i tried to install from LibreELEC-S905.aarch64-17.3_20170801.img.gz file. Inside the file, there is no install.sh file. So, when i clicked "reboot install to emmc" it's doing nothing.
Originally posted by ZZM View Post
Hi, it's the same for me, I put the tar file in the update folder like always, but I had a black screen on reboot, not even the Tronsmart Logo or LibreELEC... and I'm stuck with that, can't access the update folder anymore, I'll have to reinstall all...
There are currently 2748 users online. 0 members and 2748 guests.
