LibreELEC & OpenELEC for Tronsmart Vega S95
The renewal of the image LE (KODI 17.1) 20170223. The latest version introduces the ability to install to the internal memory without manipulation with manual renaming of the file "install.sh". In reboot menu now has the item in which , there is a reboot and unattended install LE in the internal memory (eMMC). Now the PC is only needed to write the image to the media. Everything else you can perform on the media box by pressing the buttons in the menu.
Originally posted by balbes150 View PostThe renewal of the image LE (KODI 17.1) 20170223. The latest version introduces the ability to install to the internal memory without manipulation with manual renaming of the file "install.sh". In reboot menu now has the item in which , there is a reboot and unattended install LE in the internal memory (eMMC). Now the PC is only needed to write the image to the media. Everything else you can perform on the media box by pressing the buttons in the menu.
Thanks again for your supports, I wish I could donate something to show an appreciation.
Cheers!
Originally posted by e123enitan View Post
Thanks, The new build with Internal memory (eMMC) have resolved the issue that I had with unable to boot from internal, the process simply wiped everything and install the latest and it working fine after several months of research and try and errors of several methods that proves abortive.
Cheers!
If You really want to support the development of LebreELEC, it is better to make donations on this page. All my designs are based on LE shares. I think that would be fair if You donate to a shared resource, which is the basis.
https://libreelec.tv/sponsor/
Try image 20170224 (s812), maybe he will be able to capitalize on s802.
Pls could you provide full link coz I couldn't find the folder you pointed to in this link https://yadi.sk/d/srrtn6kpnsKz2/Libreelec/KRYPTON-17
Originally posted by hscotty55 View Post
Here is the link -->> https://yadi.sk/d/mbyqouMB32E53U/20170224
Thanks, not trying to be an ass but the Link is https://yadi.sk/d/mbyqouMB32E53U/20170225_1
I have question, I have 3 boxes of Meta, I have always used your build, but I noticed is that in 2 boxes when it power up it will run through TM and LE splashes , in another box when it power up TM splash doesn't show only LE splash. The point the one with LE is my preference just becos it load very fast. So I have try to ensure that other 2 boxes load only LE splash but I couldn't.
Please, could you advice what build I need to load that will ONLY load LE splash.
HI balbes150, I dont meant to be pushy, I just wondering if you have the opportunity to review the two files, as I can see, based on eyes balling I noticed there are diff in both files, mostly in the one with no TM splash, without knowing what this are, I curious to find out how to make all the box consistent without the TM splash.
Thanks for your supportsLast edited by e123enitan; 03-01-2017, 01:49.
There are currently 1403 users online. 3 members and 1400 guests.
