LibreELEC & OpenELEC for Tronsmart Vega S95
Originally posted by balbes150 View Post
If there are errors, then a clean install.
Has anyone noticed same issue, or it was just mine system, although I must confessed that it has be very humid in this part of the world, this could have been the reason to higher temp.Last edited by e123enitan; 04 August 2017, 20:10.
Originally posted by e123enitan View Post
Thanks for the continuous efforts, the clean build works fine, one thing that I noticed is the temperature indicator is very high while the physical feels of the box seems normal, any idea why this might be?
Has any noticed same issue, was just mine system, although I must confessed that it has be very humid in this part of the world, this could have been a reason to higher temp.
balbes150, I have being experiencing issue with sound when using back end PVR, some SD and HD channels produced no sound, while in the previous build there was issue of such. I tested on Kodi 17.3 on Windows 7 everything runs fine, any suggestions to resolve this issue.
ThanksLast edited by e123enitan; 07 August 2017, 07:20.
Originally posted by e123enitan View Postbalbes150, I have being experiencing issue with sound when using back end PVR, some SD and HD channels produced no sound, while in the previous build there was issue of such. I tested on Kodi 17.3 on Windows 7 everything runs fine, any suggestions to resolve this issue.
Originally posted by e123enitan View PostHi balbes 150, should I report this issue in Kasaq Libreelec forum or Kodi forum, pls advice.
Thanks for look into the issue, however if is other codes that have caused this issue, could you pls direct me to the forum where I can post the problem for trouble shooting.
Full Log https://paste.ubuntu.com/25273953/
Here is the log of my box, for instance when switch to Live Channel Al Kass, there is sound and the picture stream freezes intermittently, I am not sure what could have caused the issue, 100% sure it's not server issue because every other devices like Kodi 17.3 on Windows 7 plays nicely without issue.
Update 20170816.
In this embodiment, a modified procedure activation TV. The system will attempt to obtain the possible settings from the TV, if this is not possible, it will use the previous version of the installation the screen resolution. Please check this option and write, if at system startup, there will be problems with the initial splash screen (the inscription LibreELEC at startup).
Cheers!Last edited by e123enitan; 17 August 2017, 22:04.
There are currently 3364 users online. 0 members and 3364 guests.
