LibreELEC & OpenELEC for Tronsmart Vega S95
Originally posted by presjar View PostI remember in the past I was able to use 3D Bluray ISO using the tronsmart box. Has anyone tested this with the openelec and kodi balbes puts together?
I used to get a popup asking to use 3D or not. I don't seem to get that popup any more.
I updated to the latest from here https://yadi.sk/d/srrtn6kpnsKz2/Libreelec/KRYPTON-17
I then did a full wipe reset. 3D ISO files are not working as 3D
Originally posted by duolly View Post
only ture-hd couldn't passthrough, DD,DTS,DTS-MA have no problem,only ture-hd
and i want to konw how to update a new version ,not just reinstall?
thx,sorry for my bad english.
Hi there,
Just followed the procedure to install Libreelec and Domoticz via docker, took me a while but it's now running !
I have a problem though.
When I restart the box, it will always restart on Android, even under Android when I reboot, I must unplug my USB sticks used for domoticz (Z-Wave and Rflink).
I'm not an expert but I think during boot, it scans USB and probably having 3 devices plugged (Z-wave, Rflink, and 8GB usb drive for LE) makes the stack longer to load, and reacts as there's no USB drive plugged.
Is there a way to force boot on the USB stick ? Or is there a way to make the timeout longer to leave the usb stack more time to load ?
Thank you for your answers !
Cheers
Ok, just installed from the shutdown menu, that's pretty cool, but I don't know the side effects. Hope I can update/change system easilyLast edited by Hiwyx; 11 May 2017, 18:08.
1. Adjust the location of connection of USB devices (swap the connectors that connect the device). All USB ports have a sequence number at the start. The launch system is configured for USB port 0. You need to achieve that, would a USB flash drive with the system was connected to the USB port 0.
2. The difference between installing via shutdown menu only that it has no choice (to replace the existing settings or to do a new installation). When you install from the menu, all available settings and data will be deleted eMMC (in eMMC copied the settings and data that are on an external drive). Ie installation via shutdown menu makes a copy of everything that You have on an external drive.
3. After installing eMMC system update is performed as usual via the catalog Update files ".tar"
Please , would someone help me .
In my Telos the wifi doesnt work at all. Which device trees do i need?
if i put any of this trees as renamed dtb.img, Libreelec wont boot. So i let device tree by default. This works for me exept wifi!
My router is setted 2,4/5Ghz . I use in 2,4ghz channel 13 and 5 ghz is auto.
There are currently 5002 users online. 3 members and 4999 guests.
